Bigger injectors - Ford Powerstroke Diesel Forum
Old 10-03-2008, 04:56 AM
Feedback Score: -1 reviews
Bigger injectors
I was thinking of going to a set of stage 1 injectors from spartan do i need to up grade my pump or can the factory pump support the stage 1 injectors?
Old 10-03-2008, 05:06 AM
International Threat
add a fuel system for sure b4.
Old 10-03-2008, 05:09 AM
I see you have DIY Fuel system with dual pumps in your sig
what did you do?
Old 10-03-2008, 07:10 AM
I was thinking of using the raptor pump 100gph for more fuel to support the bigger injectors. Can i put it inline with the factory pump?
Old 10-03-2008, 07:12 AM
Dont put anything "in-line" you need to put them in parellel to work.
Old 10-03-2008, 07:13 AM
For the 7.3's that works. I don't know about the 6.o's.
Old 10-03-2008, 07:25 AM
so how would they work parallel
I take it i would have to drill the tank for the pump but how would it connect to the engine
Old 10-03-2008, 07:27 AM
on the 7.3 you can do it 2 ways.
one the hardest, Run a pump to each head, that requires alot of plumbing.
two. pult a Y in and use the stock lines. it will just go from one line, 2 pumps next to eachother, back down to one line.
Old 10-03-2008, 07:35 AM
So i still need to put a supply line in the tank right?
Then i would y in the raptor in up stream somewhere from the factory pump correct?
Now as far as wiring i just wire it to turn on like the factory one?
