Question about surging ? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-14-2014, 11:44 AM Thread Starter
HP MACHINE's Avatar
Quoted: 157 Post(s)
Question Question about surging ?
Hello guys , I have a 2006 that we just put a rebuilt 04' turbo with a WW2
billet wheel and a 4" exhaust ( no cat ) on recently and it has developed
a "surge " ( for the lack of a better term ) between 2000 and 2500 rpm's .
It showed up after a couple of days .
It is more pronounced during driving as it approaches full temp (190 on the stat )
and is still slightly there once up to full heat soak .
Also it's more pronounced at med. throttle but if you lay into it , it's not as bad .
Just installed new fuel filters to be sure . Starts good cold and hot , seems to make
good power etc.
Any ideas ?
HP MACHINE is offline
post #2 of 8 Old 01-14-2014, 11:46 AM Thread Starter
HP MACHINE's Avatar
Quoted: 157 Post(s)
It's not bucking , just more of an RPM waver .
post #3 of 8 Old 01-14-2014, 12:35 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Can you get a video of it?
MrOneEyedBoh is online now
post #4 of 8 Old 01-14-2014, 02:43 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 136 Post(s)
Feedback Score: 3 reviews
Sounds more like you are overspeeding the turbo. Sort of like this (video below)??
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #5 of 8 Old 01-14-2014, 03:11 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Probably need to drop the VGT duty cycle a little.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 8 Old 01-14-2014, 04:13 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I tracked a pesky problem like that last year and it was the lower connection of up pipe bolts vibrated loose. Caused similiar issues
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #7 of 8 Old 01-15-2014, 05:02 AM Thread Starter
HP MACHINE's Avatar
Quoted: 157 Post(s)
Thanks guys , I've got the young lad working on some video's to load .We'll see if we
can get some AE screen shots up as I drive it .We have a GOPRO but I don't know what
the sound quality will be like .
Also , the turbo and exhaust weren't installed together , the exhaust was put on about
a week after the turbo.( Then the issue showed up ).
If all the "plumbing" is tight with no leaks , would a tune be needed (SCT) to rectify
the problem ? It is a stock truck otherwise .
post #8 of 8 Old 01-15-2014, 05:07 AM Thread Starter
HP MACHINE's Avatar
Quoted: 157 Post(s)
D#@m it , sorry I forgot to mention , the egr delete has been performed but the valve
is still intact . I don't believe it's turned off as I see readings on AE . I will see if I can
"get it together " and be more precise with my statements and descriptions .
Thank you
