tackling the EGT monster- - Ford Powerstroke Diesel Forum
 40Likes
post #1 of 147 Old 01-13-2014, 06:25 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive been fighting with egt's since Ive had my truck. Put it this way, I can very easily get the Edge to start beeping on the average on ramp, empty not towing.
I have a atlas 40 and that did help. The atlas 80 made the truck run great but egt's were terrible.
So here is my options-
1- get rid of the ficm tune all together and go with a sct tune.
2-For around $1100 I can get a complete Banks intercooler kit. I have done alot of reading and have read good and not so good about this set up.
3-Water methanol (around $900) Going this route does interest me but is this kinda like putting a band aid over a gun shot?
So I guess the smatest/cheapest thing might be to get rid of the Atlas 40 tune. And tune the truck with the sct???
I guess Im just askin for your thoughts on this. Am I missing something? Should I be looking a diffrent direction?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 147 Old 01-13-2014, 06:38 AM
peixinho's Avatar
Quoted: 207 Post(s)
So you are having problems with cruising and lite accleration egts... Not WOT egts? or is it all of the above?
Have you verified nothing is wrong?
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #3 of 147 Old 01-13-2014, 06:46 AM
Heavy_GD's Avatar
Quoted: 1500 Post(s)
Feedback Score: 3 reviews
I was going to ask the same things... also are we sure the probe/sensor are reading correctly?
GD
Heavy_GD is offline
post #4 of 147 Old 01-13-2014, 06:57 AM
peixinho's Avatar
Quoted: 207 Post(s)
I also forgot to ask... Are you talking about when you are empty or towing?
Here are a couple of things that could cause the issues you describe:
Leaking up pipes
Leaking ypipe to turbo connection
Boost leaks
Check, fix, and clean all sensors, tubes, and connections
IAT
MAF
MAP
EBP
ICP
IPR
VGT
ETC...
A slightly chewed up turbine is hard to notice unless you pull and open up the turbo. I have had a few experimental turbos that had this happen. Everything seemed ok except for pretty high egts. I pulled the turbo and the turbine was chewed up.
Here are a couple of mods that will help:
11 blade single plane billet wheel upgrade
Ported intake manifold (number 1 choice)
Upgraded intercooler
Water injection
I know this may sound werid. But if your max WOT egts are fine and you are just trying to help out your crusing and/or lite acceleration the you could try an 06-07 with a billet wheel. The 06-07 turbo will spool faster and operate much more efficiently at lower rpms and during lite acceleration. (but it will not perform as well up top and will not make as much power)
KC Turbos
peixinho is offline
post #5 of 147 Old 01-13-2014, 06:59 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
As far as the probe reading correctly no I cannot guarentee that its reading correctly. I installed it according to the directions I had and the videos I watched. Is their some great way to check the #'s?
The egt's seem to be always a bit hot. I live at 6000' plus in very dry air in the mountains. From what Ive read the thein air and dry air can effect egt's alot so this is why I was looking at water methanol.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 147 Old 01-13-2014, 06:59 AM
Quoted: 8 Post(s)
I just ran into this problem and it turned out to be my gauge. Though they are not cheap pick up a new one and check it out.
06Mike is offline
post #7 of 147 Old 01-13-2014, 07:16 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
This is running empty. Loaded its not good.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 147 Old 01-13-2014, 07:18 AM
peixinho's Avatar
Quoted: 207 Post(s)
What are your actually numbers... just for reference
Idle
Cruising at 70mph flat ground
Lite 1/4 throttle 0-70mph
Max WOT egts 0-70mph
KC Turbos
peixinho is offline
post #9 of 147 Old 01-13-2014, 07:19 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
How about posting some actual numbers and the particulars at the time so we can see what you are talking about.
RIP Mitch
the Org crew
PGreenSVT is offline
post #10 of 147 Old 01-13-2014, 07:20 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
peixinho-you bring up leaking up pipes,I do find when the truck is just warming up in the morning I have a decent bit of exhaust smell in the cab. Once I start down the road it all goes away.
Thank you for what sensor's to check I guess this could be a good place to start.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
