Something New ... Negative Boost PSI - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 01-12-2014, 02:33 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Ok, went out to hammer on the truck and finish the re-learn.
Noticed if i roll into in second the Boost builds 5 9 13 21 28 then - 8 -12 -6 +9 12 16 21 Etc.
I have never seen - Boost on this truck via the scangauge in it's life.
2005 reading boost from thru MAF sensor.
I can put a analog gauge on it for the time being because there is no way what the SGII is showing is what is going on, unless the sensor is crap.
MAhybe i should scrap this code and reload the SGII ?
Lastly, trans can't learn and get past the 1 -2 or 2-3 shift flare if WOT is used, feather it a bit and it will shift and hit 50 inside a block but that won't win any race with a Goat.
So sounds like I need a MAF sensor and new Tranny?
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 13 Old 01-12-2014, 03:53 PM
My Insight will bounce the readings to negative and back when I'm full throttle. I have never figured out why. The dash gage stays steady.
WLDHRSE is offline
post #3 of 13 Old 01-12-2014, 04:41 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
I believe it's the PID being selected by the OBDII monitor. We had this problem with DashBoss, in the PCM there are like 3 different boost PID's to use, if you selected the wrong PID, you got a negative boost reading. I just can't remember the reasoning for the PCM having 3 different sources of PID's.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 13 Old 01-12-2014, 05:42 PM Thread Starter
Quoted: 2 Post(s)
But why now? it has never done this before ? ? ?
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #5 of 13 Old 01-12-2014, 05:45 PM
Scolesy8's Avatar
Are you running a different tune atall??
Zach
'04 F250 6.0 with some go go
Scolesy8 is offline
post #6 of 13 Old 01-12-2014, 05:52 PM
04cr450's Avatar
Never had this issue on my edge cs. hmmm interesting
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #7 of 13 Old 01-12-2014, 08:14 PM Thread Starter
Quoted: 2 Post(s)
Hmmm, I"m running Jess' race tune, i guess i could run the street or any of my others to see if it does it.
I'm pretty sure i've ran this tune before.
Also looks like i'll need a tranny too, but can limp around until I can save the money.
Dang this never ends.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #8 of 13 Old 01-13-2014, 05:49 AM
Powerstroke Techie
Lilpooh's Avatar
Boost is read thru the MAP sensor, not the MAF. Check your MAP hose for clogging, and hose fitting in the intake. Check MAP sensor plug/wiring for damage.
Lilpooh is offline
post #9 of 13 Old 01-13-2014, 05:53 AM Thread Starter
Quoted: 2 Post(s)
It's all fine and checked.
I'll try a different tune and see if that makes any difference.
Weird that it just started this after the new injectors & turbo were installed.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #10 of 13 Old 01-13-2014, 06:53 AM
T diesel's Avatar
Quoted: 20 Post(s)
My stock 06 with the scangauge did it all the time.
2013 F-250 lariat scsb FX4.
6.2. 3.73 lockers. Rear wheel liners.
Camper package. Pullrite 18K lb Superslide, Line X sprayed bed.
Krown rust protected.
"That which can be asserted without evidence, can be dismissed without evidence"
- Christopher Hitchens
T diesel is offline
