03 turbo on 06!!! ??? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 01-10-2014, 09:39 PM Thread Starter
eddie06f350harley's Avatar
hey fellas so today i installed my 03 spare turbo on my 06, for that nice whistle, it seemed that the truck ran a little sluggish of the line, maybe because of the less vanes? but then after the boost lag it goes, do you guys think that if i install the wicked wheel for the 03 turbo will it help?, but i don't want it to loose that sexy jet sound any help would be appreciated!!!!
eddie06f350harley is offline
post #2 of 13 Old 01-10-2014, 09:50 PM
sprksonu's Avatar
you picked up the extra whistle from the turbine side going from a 13 blade to a 10 blade. the 13 blade has less turbo lag but does not flow as well as the 10 blade on the high end flow. there is more options than the wicked wheel, there is MTW (mad turbo werks) and james from barder turbo, do a google search and you will find them. as for the whistle you will only gain not lose any and it will reduce turbo lag. for the 200$ i would say its worth it.
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 13 Old 01-10-2014, 09:53 PM Thread Starter
yah thats what i was hoping someone would say that! in you opinion what wheel would you do? so i won't loose the whistle if anything it will make it louder, and reduce lag **** I'm sold but what wheel?
post #4 of 13 Old 01-10-2014, 10:05 PM
sprksonu's Avatar
i would give james at barder turbo a shout, great customer service and normally can ship the same day of purchase.
sprksonu is offline
post #5 of 13 Old 01-10-2014, 10:11 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
I did the same thing and installed the Diesel site whisked wheel 2. No loss of the whistle and definitely helped the off the line pull it seemed to lose. Reduced EGT too.
Need to update my tunes and I'm sure it will help too
2005 F350 CCLB FX4
ID:	224530   Click image for larger version
2005 F350 CCLB FX4
juniorssrollin is offline
post #6 of 13 Old 01-10-2014, 10:17 PM Thread Starter
tunes you say?
post #7 of 13 Old 01-10-2014, 10:26 PM
sprksonu's Avatar
Here is mine from barder turbo. You don't need a custom tune when changing to a billet wheel.
sprksonu is offline
post #8 of 13 Old 01-10-2014, 10:31 PM Thread Starter
It looks similar to the ww2 what do recommend?!!!!
post #9 of 13 Old 01-10-2014, 10:34 PM
sprksonu's Avatar
they are all the same it depends if you get a single plane or dual plane that is the only difference. get one from barder and save some$$$
sprksonu is offline
post #10 of 13 Old 01-10-2014, 10:35 PM Thread Starter
I'll look into it thanks guys!!!
