SCT Livewire problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-10-2014, 07:24 PM Thread Starter
So I just finished installing a SCT Livewire 5015 on a 2006 f450 that I replaced heads (UCF oringed) and did studs etc.... Problem I am having is the monitor feature doesn't work. When I open it all it says is "waiting for data" Now if I look at vehicle information it shows the VIN and the strategies and I loaded a canned trans tune and turned off the EGR and all of that seemed to work fine. Any ideas? I would think if there was a communication issue it wouldnt program? Also the truck runs fine too... Thanks for any help....
2005 F350 King Ranch Dually
UCF Machine O-ringed cylinder heads, ARP Studs, Wicked Wheel 2, Atlas 40 FICM, Rudy's y-pipe, IPR Gen II EGR Delete, Riff Raff boots
SCT Livewire TS Tunes from TSD, Gearhead, Tony Wildman and Vivian
MBRP Cool duals SS exhaust
pjm1 is offline
post #2 of 3 Old 01-10-2014, 07:31 PM
WetxMud's Avatar
i was told that when I received mine to go to SCT home page and check for an update. Try that and see if that works for you. Worse case scenario if that doesnt work you can call SCT support. Hope this helps.
WetxMud is offline
post #3 of 3 Old 01-10-2014, 07:40 PM Thread Starter
Thanks for the idea, I may try that still. According to the information on the device info screen it is the current firmware 1.1.1.6 but who knows I guess?
pjm1 is offline
