ReGear or ReAxle ? - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By william_ace
  • 1 Post By jetjock15
post #1 of 10 Old 01-10-2014, 06:34 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
ReGear or ReAxle ?
Pondering a re-gear but searched around to find a complete axle.
Wondering how difficult it would be to regear in the driveway vs. exchanging the entire axle.
Of course I would then have to do the front, but it would give me the option of running the rear to see if i liked it prior to exchanging both ends only to find out I preferred 3.73's and keep my 37's.
2007 Ford F-250 Super Duty Rear Axle Assembly*(pickup), (single rear wheels), diesel, (6.0L), 4.10 ratio; (pickup), (single rear wheels), gasoline, 6.8L, 4.10 ratio*(Omaha, Nebraska, 435-02246E, Very Good, $786.00 )
Lastly, is there a market for 3.73's or are most folks seeking 4.10's ?
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 10 Old 01-10-2014, 07:45 AM
william_ace's Avatar
Quoted: 2 Post(s)
I would do a regear. IMO it is easier than swapping the whole axle. While you are in there, replace the seals and bearings and you basically have a new axle. You also have the option of throwing in a traction aid when you regear. It may be a bit more expensive, but with it. With a used axle, thats what you get. . . a used axle. That's my opinion anyhow.
1fastTRX likes this.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #3 of 10 Old 01-10-2014, 08:34 AM
The cost of a used front Dana 60 alone is reason enough to just swap the gears yourself.
BTW, 4.30s would have the same effect as the OEM 3.73/31.5" tire.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 10 Old 01-10-2014, 08:34 AM
peixinho's Avatar
Quoted: 217 Post(s)
Hey denny... i might have missed it but how are your new injectors running?
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #5 of 10 Old 01-10-2014, 10:09 AM Thread Starter
Quoted: 2 Post(s)
I still have a long 20 second crank to initial start, started it 7 times so far over the week, haven't driven it for more than a few miles.
It's running real strong. i have to reconnect the CCV mod tube tonight and hopefully that will alleviate the little bit of smoke emanating up around the rear of the engine.
I've verified the up pipes are tight and the turbo isn't leaking so once everything gets settled in i'll venture a little farther from the house.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #6 of 10 Old 01-10-2014, 10:26 AM
peixinho's Avatar
Quoted: 217 Post(s)
Nice! Glad everything worked out.
You will not get the truck to start quicker until you beat on it a little bit. You need to work the air out and the best way to do that is put the most pressure and volume possible through the oil and fuel...
Go have a little fun and then try starting it afterwards
KC Turbos
peixinho is offline
post #7 of 10 Old 01-10-2014, 01:05 PM
jetjock15's Avatar
Quoted: 113 Post(s)
Your question was about "difficulty". I can drop in new axle in under two hours complete with no special tools. Swapping gears In rear end takes me 4.5 hours and need some special tools, so swapping an axle would be "easier". All that said a re-gear is most definitely the right way to go.
william_ace likes this.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 10 Old 01-11-2014, 08:12 AM
scrapecc's Avatar
You'll need the right tools to do it. I know guys that do it for a living that have stock parts machined down to ease the process of getting the shimming right.
I'm parting out a truck with 4/30s in it right now!
scrapecc is offline
post #9 of 10 Old 01-13-2014, 07:35 PM
Jon_001's Avatar
I rebuilt my Dana 80 axle in February of 2013. It was the first axle I had ever re-geared / rebuilt. I did not have a bearing preload measurement tool. It took me nine days from start to finish with 30 hours of actual work. The abbreviated timeline was: make special tools, buy socket to fit pinion nut, tear down, order parts, clean, measure components, parts arrive, re-clean, assemble, measure, tweak shims, measure, tweak shims, check contact pattern, when pass install new seal, install yoke, install new nut and washer, install cover, add oil, reattach drive shaft, burn rubber.
I bet I put the pinion and case in and out at least 6 times each before I was satisfied with the fit. I must have got it right though because I pulled a 12,000 pound trailer on a 3000 mile round trip 4 weeks later and the case temp never got above 175 degrees F. I have not had any problems with the axle to date.
I rebuilt a Dana 60 axle for my neighbor in March 2013 and it only took me 10 hours of actual work. Most of the time savings was due to having special tools already made. He has not reported any problems with his axle yet.
If you choose to re-gear the axle yourself I will offer the following advice.
1. Use Dana gears if you plan to keep the truck for a long time. I used Yukon gears in the first axle I rebuilt. The surface texture left something to be desired, and the pinion gear run-out was barely within tolerance. Tooth to tooth backlash variation was as high as .002" and the target .005"-.008" factory specified backlash value was a bit out of reach. I ended up settling for .004"-.009" range, and that is with a case that had no significant run-out.
For the Dana 60 axle I rebuilt I used Dana gears, and there was a big difference. The surface texture was very smooth and run-out was very low. Tooth to tooth variation in backlash was less than .001" and the variation of .005"-.007" backlash was well within the ford specification. I suspect that the majority of this variation was actually coming from the case itself and not the gears based on the .001" run-out that was recorded during pre assembly measurement.
2. Make sure you have an impact wrench that can deliver 1,200 ft-lb of nut busting torque to get that pinion nut off or you could find yourself with some tired arms. Also avoid using a pipe wrench to hold the pinion yoke unless you plan on buying a new one. I recommend building or buying a tool with flat faces to hold the yoke while that impact wrench is getting things done for you.
3. That preload measurement tool can save you a lot of time if you can get one from somewhere. I've never used one, but after the nth time of in and out with the pinion to get the shims added between bearings I was definitely wishing I had one.
4. A bumper jack or equivalent system is great at allowing the axle to hang fully suspended. This is a must if you have a rear fuel tank.
5. Have an extra pinion seal on hand just in case the first one doesn't get in straight on your first attempt.
That got long fast. If you would like more info/advice feel free to ask. If not there's always the "other guys on the internet"
Jon
Jon_001 is offline
post #10 of 10 Old 01-13-2014, 07:47 PM
ZMANN's Avatar
Quoted: 1670 Post(s)
my advice is have it done by a shop that deals in re gearing
do the rear and decide if you like it then do the front you screw up a gear job and you may be looking for a new axle anyway
does DANA make gears for the sterling rear ??
We Miss you Ronnie
ZMANN is offline
