Help out your head gaskets?? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-10-2014, 12:46 AM Thread Starter
madpowerstroke's Avatar
I was told by a diesel performance shop about a trick they use to help out the cooling of the heads to help the head gaskets. They use the trick on every head job they do, arp studs, ford factory head gaskets, and they run a line from the back of the each head from the coolant plug to return to the erg delete or the heater line. They have learned that the heads have a dead area on each of the heads on the back cylinders which cause the coolant to heated hotter than the rest, so by getting coolant to flow and not dead end it keeps the back cylinders of the heads cooler. They have seen the head gaskets last longer and be able to handle more abuse than not having the coolant dead ending. Just wanted to pass on the info, I plan on doing this on the MTW white truck, I may even do it to the average Joe truck too later in that build. Please share any thoughts on this.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #2 of 15 Old 01-10-2014, 02:43 AM
Swackhamer's Avatar
I did the rear corner vents when I did my gasket job. I ran them back to Tstat.
We have done it on our circle track engines for years, also GM LS engines have head corner vents as well. I can say I have never had any bad results.
04 F250 Leveled, Studded, Atlas40,SRL+, Blue spring, My 304 s/s Up Pipes, KC stg II, My Ported intake, 4" exhaust, My Head vents, Cat ELC and coolant filter, My Custom rear Bumper, My 304 degas tank, More home brew mods in the works
Swackhamer is offline
post #3 of 15 Old 01-10-2014, 03:43 AM
USAFBowman's Avatar
I'm also thinking about doing something like this to my truck when I do my head work. I'm in to see what people have to say about this.
USAFBowman is offline
post #4 of 15 Old 01-10-2014, 04:45 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Elite Diesel has the coolant line kit for the heads. Not sure I'd that's the company you're referring to...but that kit has been out for years. There are so many trucks out there that get abused and don't run the coolant lines for the heads and have no issues with head gaskets. It may help with coolant flow through the heads...but i don't that's causing alot of the gasket failures
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #5 of 15 Old 01-10-2014, 05:00 AM
strokin6L's Avatar
Quoted: 3 Post(s)
www.elitedieselengineering.com - 60LCoolantCirculationLineKit
Adrian...I'm assuming this is what you're talking about?
post #6 of 15 Old 01-10-2014, 05:45 AM
peixinho's Avatar
Quoted: 193 Post(s)
Well this is very interesting! I am gonna do this for sure!
Thanks Adrian
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #7 of 15 Old 01-10-2014, 06:13 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The coolant lines for the heads have been out for years. I've got the ATS lines.
I've never seen any hard data/proof if the lines actually keep the heads cooler or not.
Just a FYI for those who don't understand, in order to install these coolant lines, the heads have to be removed from the block. The heads get drilled/tapped, then the thermostat housing gets drilled/tapped.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #8 of 15 Old 01-10-2014, 10:37 AM Thread Starter
I know it has been out, but there are a lot of members that may not know. I didn't know until the diesel performance shop told me about it. As far as hard data I don't have any either, but wanted to see what some other might have known. Rich you are right not a easy type of mod, but if heads are off due to studs or gasket failure might be something to consider. There are more companys that make the kits other then tbe ones mention. I might try to make my own, will it do somthing or not, not sure, but getting feedback helps out for sure.
post #9 of 15 Old 01-10-2014, 02:48 PM
ZIKA's Avatar
I bought these lines from Elite Diesel about 4-5 years and while I dont have any hard data, I did notice that my truck took longer to heat up but the average running temp stayed the same. Mine return back to the T-Stat housing.
When you take the heads off of trucks that do not have them it looks like the coolant just sits in the back of the head and cavitates. Someone did a thermal image years back and it showed the rear of the head was much hotter than the rest of it.
One thing... Couple these lines with a regulated return system and a coolant bypass and you got hoses running everywhere.
Here are a couple pictures of them from a couple years ago.
Name:	6.0 Day 1 005.jpg
ID:	224394   Click image for larger version
Name:	6.0 Assembly 006.jpg
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
post #10 of 15 Old 01-10-2014, 02:51 PM
Heavy_GD's Avatar
Quoted: 1420 Post(s)
I hadnt heard about this, thanks.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
