Anyone got O-ring heads out there - Ford Powerstroke Diesel Forum
 51Likes
post #1 of 333 Old 01-09-2014, 12:33 PM Thread Starter
peixinho's Avatar
Quoted: 207 Post(s)
I am looking for first hand experience from either shops or owners. Don't take this the wrong way but I am not looking for heresay... Heresay is when you post something you think you heard from some
My heads recently started leaking after doing the typical oem headgaskets, arp studs, proper machine work, proper prep work, etc... etc... Now my heads have a very slight leak in them. 90% of people out there would not have even noticed. It does not puke, does not lose coolant, does not smoke, etc... The only reason I notice is by putting on a gauge and testing. And the test in not really obvious either because the leak is so small. It also only leaks when pushing about 40psi boost and hitting around 600hp. It does not leak at all during typical driving. I know there are a lot of guys pushing more power on just oem gaskets and studs... but I doubt anyone of them have checked if they are leaking and many of them don't tow like me. I am not going to be doing the same thing again so no need to fill the thread up with the typical... "plenty of guys make big power with OEM headgaskets an studs" Thanks
Well if I go in there again I want to do it right and I have been looking into O-ring heads. NOT FIRE RING HEADS. IF YOU DON'T KNOW THE DIFFERENCE THEN PLEASE DON'T POST YOUR EXPERIENCE.
I would really appreciate any first hand experience from anyone running o-ring heads.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #2 of 333 Old 01-09-2014, 12:56 PM
FWIW I just got done doing heads / studs, etc... on my truck and went with O-ringed heads from UCF Machine Shop. Granted I only have 1000 miles since I finished it but they have been flawless. I tow gooseneck trailers normally loaded heavy (up to 18K) and I live at 7200' elevation. In my opinion they seem to be the only way to go. Check out UCF's website they seem to know whats up with the 6.0 heads and they have a page documenting a head job. Wish I had more miles to go by, but like you I actually use my truck to tow with and dont want future problems so I guess time will tell....
2005 F350 King Ranch Dually
UCF Machine O-ringed cylinder heads, ARP Studs, Wicked Wheel 2, Atlas 40 FICM, Rudy's y-pipe, IPR Gen II EGR Delete, Riff Raff boots
SCT Livewire TS Tunes from TSD, Gearhead, Tony Wildman and Vivian
MBRP Cool duals SS exhaust
pjm1 is offline
The Following 2 Users Say Thank You to pjm1 For This Useful Post:
peixinho (01-09-2014), windrunner408 (01-09-2014)
post #3 of 333 Old 01-09-2014, 01:02 PM Thread Starter
peixinho's Avatar
Quoted: 207 Post(s)
Thanks for your input
KC Turbos
peixinho is offline
post #4 of 333 Old 01-09-2014, 02:15 PM
Gadgetguru's Avatar
Quoted: 448 Post(s)
Garage
Guess I know where I'm taking my heads. I've been calling around trying to find a good place to take my heads when I do my studs. Theses guys are about 40 minutes from the house.
- Michael
2017 F350 Lariat DRW - SHE'S HERE!!! 29NOV16
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
'11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Gadgetguru is offline
post #5 of 333 Old 01-09-2014, 02:46 PM
Scolesy8's Avatar
Charlie, this would be quite a ways from where your located at but not too terribly far from where Warrens is, Liberator performance over in Carlisle, PA does their own O-ring heads. talked with some of their guys at a show a while back and of course they had a big fancy display but they guys really knew what they were talking about and did a nice job explaining things (atleast they sure seemed like it)
Zach
'04 F250 6.0 with some go go
Scolesy8 is offline
The Following User Says Thank You to Scolesy8 For This Useful Post:
peixinho (01-10-2014)
post #6 of 333 Old 01-09-2014, 04:21 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
im begining to wonder if some of the 'o ring' faliures ive read about were actually 'fire ring' failures and folks just didnt know the difference. ive personally seen several sets of heads come in with burned up fire rings, they go right in the scrap bin lol. im resesrching o ringing a lot now...we dont o ring our motors at work because we havent had issues with just studs and gaskets, but our motors are OE replacement, not high performance with 50 psi of boost amd what not. We've done o ringing in thr past on blown alcohal injected BBC motors, and we've talked about adding it as an option...but ive seen/heard about lots of 6.0 failures...seen plenty of sucess stories too, but thus far the risk hasnt been worth the cost for our production engines. Im very curious to see how o ringed heads hold up long term...heard mixed results with fire rings on 6.0's burning up ever time. Anyway, subscribed...anxious to hear more from people using o rings.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #7 of 333 Old 01-09-2014, 04:30 PM
strokin6L's Avatar
Quoted: 4 Post(s)
I've had o-ringed heads on my truck since spring of '06. About 35k miles so far with some drag racing, truck pulling, dyno runs and burn outs without any issues what so ever.
ODAWG714 likes this.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
The Following User Says Thank You to strokin6L For This Useful Post:
ODAWG714 (01-09-2014)
post #8 of 333 Old 01-09-2014, 04:38 PM
Gadgetguru, I hope these heads work well, I hate to endorse something that turns out to be ?&*^. They really seemed to be knowledgeable on the 6.0's though and very adamant about the use of O-rings.
Scolesy8, it is my understanding that UCF does the heads for Liberator? Could be wrong though...
strokin6L, very happy to hear oringed heads have been holding up good for you!!
pjm1 is offline
post #9 of 333 Old 01-09-2014, 04:39 PM
Im in the same boat, my head gaskets are leaking more than yours but with a stock tune its barely noticeable. Like you i put a gauge on the coolant system and figured it out. I've spoken with UCF and im going to go that route here in the next month or so. They offer polishing of the ports too for another 500. In on the fence about the polishing, but im going to get a junk yard intake manifold and cut it open and port it to install when i do the heads.
power43 is offline
post #10 of 333 Old 01-09-2014, 05:10 PM
Gadgetguru's Avatar
Quoted: 448 Post(s)
Garage
No worries. Haven't been able to find someplace familiar with 6.0 heads so UCF might work out for me. Makes sense about Liberator if correct since they are both in Carlisle.
- Michael
- Click
for details
for details
for details
