Best turbo for the money?? - Ford Powerstroke Diesel Forum
 69Likes
post #1 of 88 Old 01-08-2014, 08:31 PM Thread Starter
HICKatvRACER17's Avatar
I've done a little research on this ... and didn't get very far..
I realize everyones definition of "best turbo" is probably different. But I just want to see what options there are without breaking the bank, and to see what everyones opinion was on each brand.
Check my sig for my mods to see what would work for me
05' 250 FX4: Studded, Deleted, Airaid, Stage 1 Sticks, 5" MBRP Straight, 7" Black Tip, Livewire w/ Custom Tunes, Foglight Zoodad & Blue Spring Mods, STC Update, Harley Headlights & Grill, Recon Smoked Cab & Tail Lights, 6" Pro-Comp Lift, 37" Trail Grapplers, 17" Helo's, Iron Cross Steps, Matching Bushwackers
HICKatvRACER17 is offline
post #2 of 88 Old 01-08-2014, 08:53 PM
Quoted: 8 Post(s)
What is the purpose of your truck? Towing, cruising, track, dyno days, etc. the experienced guys are going to ask this anyway!
Sent from AutoGuide.com App
2005 F250 FX4 6.0 PowerStroke, Dashboss, Swamps 58V FICM, PHP Atlas 40 tune, Tony Wildman Extreme Tune, IPR Coolant filter, ELC Coolant, EGR....nevermind, updated stc, more to come!
Babyboy70363 is offline
post #3 of 88 Old 01-09-2014, 03:53 AM
Barder Stage 3!
bondajb and ODAWG714 like this.
WLDHRSE is offline
post #4 of 88 Old 01-09-2014, 04:13 AM
bondajb's Avatar
Very happy with my BARDER STG2. .
I recommend any of Barders built from a new pmax..
ODAWG714 and Merc82 like this.
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #5 of 88 Old 01-09-2014, 05:53 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Originally Posted by bondajb View Post
...I recommend any of Barders built from a new pmax...
I have to agree with this. I would've originally said to just go with a Powermax and a billet wheel; HOWEVER, considering the fact that you can get a 65mm billet wheeled Powermax from Barder for basically the same price as you would pay for a Pmax and billet wheel (63mm) that is assembly balanced and has great customer service, I think is VERY HARD to beat... JMO of course.
WLDHRSE and ODAWG714 like this.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 88 Old 01-09-2014, 06:42 AM
peixinho's Avatar
Quoted: 191 Post(s)
A lot also depends on what you are looking/hoping for.
What are you end goals?
Do you ever plan on adding any other mods?
How much do you tow?
What size nozzles do you 175s have?
Do you ever plan on replacing the transmission?
Sounds like you could end up with any of the good choices out there.
A stage 1 will spool faster than the rest and make the truck feel lighter, but it will probably make the least amount of power. (also the cheapest)
A stage 2 is only just slightly bigger than a stage 1. (63.5 vs 64.7) It will make a little more power and lots of people have been very impressed with it.
A stage 3 is a pretty big turbo. It will by far make the most power. Tuning has come a long way and you can get a stage 3 to spool just as good as a stage 1 or stage 2 (with the 10 bladed wheel).
I would decide a budget... 1000, 1500, 2000?
Then decide how much power you want... 450, 485, 500+
Also figure out if you want quicker spool or more power
Dirty_Stroke likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #7 of 88 Old 01-09-2014, 08:21 AM
bondajb's Avatar
My BARDER STG2 spools as fast as my mtw stg1...
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
bondajb is offline
post #8 of 88 Old 01-09-2014, 08:47 AM
Barder or mtw turbo would be good either way. Depends on your budget and personal preference really.
2006 f250
on 37s
few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #9 of 88 Old 01-09-2014, 08:55 AM
BACKYARDIGAN
Quoted: 4 Post(s)
KC Turbos are also seeming to be doing REALLY well with the initial testing so time will tell... I do know that they are also competitively priced and built REALLY well... There are A LOT of great VGT options out there for folks now that are basically win win...
Nate
The Following User Says Thank You to windrunner408 For This Useful Post:
peixinho (01-09-2014)
post #10 of 88 Old 01-09-2014, 10:35 AM Thread Starter
I really appreciate all of the input!
Basically my truck is my daily driver. With frequent light towing (snowmobiles or atvs) and about once a month a loaded car trailer. I don't need a billion ponies, just something with some bang, for good street use for under $2000 if possible. and id like to match it to my mods.
im not exactly sure on injectors. I bought the truck with injectors. 2 failed so I sent them to industrial to match them and they said they built them and they are stock injectors with their 175 nozzles. weird thing is, when I got them, my receipt said they were their "race1" 175cc injector. so whatever that translates to lol.
