VXBC9?? vane sweep - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-08-2014, 07:32 PM Thread Starter
VXBC9?? vane sweep
Does anyone know what vxbc9xx strategy that has vane cycle? The current one is a vxbc9F2 and the older one was a vxbc9na. Just looking for the current one to have a tune written in it with out paying for a reflash.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #2 of 6 Old 01-08-2014, 08:29 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
All of the vxbc9 series should have it
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 6 Old 01-09-2014, 02:06 PM
HP MACHINE's Avatar
Quoted: 104 Post(s)
Can you see this happen watching a guage ( CTS etc. ) in the duty cycle ? If so ,how
much % change would you see ?
HP MACHINE is offline
post #4 of 6 Old 01-09-2014, 03:52 PM
Scolesy8's Avatar
my VXAP2N2 has the full sweep in it. it'd be nice if there was some way of telling what the different strategies do or are for though...
Zach
'04 F250 6.0 with some go go
Scolesy8 is offline
post #5 of 6 Old 01-09-2014, 04:42 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Yes, the VGT% will change from 14%-85% and you will hear the truck exhaust go from a low rumble to at high rumble or whistle.
The PCM commands the variable geometry turbo actuator duty cycle from 15% to 85% in a step pattern to help the turbo vanes achieve full movement. Vane sweep occurs when the following conditions are present:
The vehicle is stopped.
The EGR is commanded off.
The engine speed is less than 1,160 RPM.
The engine oil temperature is greater than a calibrated value.
Vane sweep repeats approximately every hour if the previous conditions still exist. Vane sweep may occur during scan tool commanded test functions.
Here is a video with using AE.
http://youtu.be/WCUUHeW0avk
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 6 Old 01-09-2014, 04:44 PM
Powerstroke Techie
Lilpooh's Avatar
I only have this link saved of the early VXAM strategies for the 03-early 04 PCM.
http://www.backglass.org/duncan/calsum6.pdf
Lilpooh is offline
