Cylinder 6 contribution code - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 01-07-2014, 10:17 PM Thread Starter
borsky4's Avatar
So I was driving down the highway in od and I leaned into the throttle and I noticed a bad vibration. Checked codes came up cylinder #6 cont code, drove it home assuming injector issue. Fired it up next day o drive to neighbours shop to asses the situation, started ok. ran rough though. backed out into street and when i put into gear it stalled, and barely started. once i got it running I idled ok still missing, as soon as I put it in gear it wanted to stall, mnaged to get it two blocks to the shop, opened hood and there was oil and seemed like fuel (hard to tell) on top of engine and blowing out of dipstick and inside of intake from ccv. I thought it was an injector issue. But could it be a engine issue? in the morning the day before it happened it ran and drove around fine. Just kinda came outa nowhere if it was mechanical failure I think it woulda happened while reving at least...
2006 CC SB, SRW, Barder stg #2, Ported manifold, Warren 190 30's, banks CAC, SCT Tuned by/IDP, IDP ficm tunes, nadp trans, fluidampr, FASS LP, Driven RR, edge insight, HPODS, BD ex manifolds, HD y pipe all ceramic coated & wrapped, UCF O-ringed heads with arp's, Colt stg 1 cam with RCD springs and tubes,
6" lift/trac bars, 37's 4:30 gears, Future mods: non VGT T4 64mm BASB
borsky4 is offline
post #2 of 16 Old 01-08-2014, 04:29 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1741 Post(s)
Feedback Score: 4 reviews
This might be from far left field, but the only time I know your crankcase gets pressurized like that is if you've got a hole in your piston . That'll be the first time I've heard of it on a 6.0 though..can you do a compression check just to rule it out?
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 16 Old 01-08-2014, 06:29 AM Thread Starter
borsky4's Avatar
This is my fear, but it doesn't make sense just because of how it came about, wouldn't it come on while the engine was being pushed to the limit? not just cruising down the highway? Is it possible that the injector could fail internally and feed fuel into the oil causing excess fuel and oil to vent out ccv and dip stick...
borsky4 is offline
post #4 of 16 Old 01-08-2014, 06:51 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yup sounds to me like a cracked piston pressurizing the system.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 16 Old 01-08-2014, 08:19 AM Thread Starter
borsky4's Avatar
Yes I guess I am comin to terms with this...fak!
Heavy_GD likes this.
borsky4 is offline
post #6 of 16 Old 01-08-2014, 08:48 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Its not unheard of in a 6.4. This is the first i have heard of in a 6.0.
08 F350 cc/sb 4X4
post #7 of 16 Old 01-08-2014, 09:10 AM
Customer brought one in with a miss fire and smoke. Found out it was cylinder 5. No compression pulled injector and tip was partially missing. Pulled cylinder head and the injector acted like a torch, cut a groove thru the piston and almost cut a hole thru the cylinder wall. It was pretty interesting.
Diesel Equipment service manager lead technician
jpott62 is offline
post #8 of 16 Old 01-08-2014, 10:50 AM Thread Starter
borsky4's Avatar
Injector looks good, tried to scope it but it didn't fit in injector hole. Could it be just a broken ring?
borsky4 is offline
post #9 of 16 Old 01-08-2014, 11:09 AM
Possible, do you have access to a compression test adapter? If so you can put air pressure in the cylinder to see if it's going the the crankcase, down the tailpipe, or out the intake. Either way sounds like the engine may need to come out.
jpott62 is offline
post #10 of 16 Old 01-10-2014, 06:48 PM Thread Starter
borsky4's Avatar
Pistons cracked says snap on boroscope
borsky4 is offline
