2-3 Shift - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-07-2014, 03:38 PM Thread Starter
2-3 Shift
I have an 04 and Im having some weird issues. The 2-3 shift is very hard during relearn and if tranny temps are below 80 degrees. It also has a hard 3-2 downshift at the same time the 2-3 upshift is acting up. Here is the weird thing I had a tranny that was built by warren diesel and it didn't do that but because of tuning and a converter going bad it had to be rebuilt again. Andy rebuilt it again and now I have this problem. He suggested to change computer and the transmission wiring harness and still have the same problems. He has said that he didn't doing anything different from one trans to the other and is just saying the tuning issue is because its an 04 and they are hard to tune. I have tried srl and looney wild and they both don't shift right. Sorry for the long post but this is driving me crazy and Im on the verge of selling the truck but don't feel right pawning this off on someone else.
Amstaff is offline
post #2 of 11 Old 01-07-2014, 05:52 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
have you asked the tuners about it? they can dial the shift pressure in on the tune...might take a few revisions back and forth, but I agree it sounds like a tuning issue
out of curiosity, what converter were you using that went bad?.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #3 of 11 Old 01-07-2014, 06:16 PM Thread Starter
The srl I had for a couple years and it seemed fine then get a tranny and it goes to crap. Matt actually still sent me a revision and it still did the exact thing. Looney wild was better but not right she sent a couple revisions but it didn't do anything plus I don't like the tune, the light switch effect sucks. The hard upshift and downshift happens stock or tuned and the other crappy shifting happens when tuned. Andy has actually built me three transmissions. The first one the converter went after a month and it was the cheap one from PATC that he used to use, so after that I upgraded to a PI converter. But then a couple months later broke the input shaft and trashed a second converter. The last one I ran stock for a while then found someone local to do a tune and it shifts ok but not great so I'm thinking about having him dyno tune it to get it better. I guess the biggest problem is the bad shifting during relearn and when the tranny is cold. Because when its cold out it can idle for 10-15 minutes in the morning and the temp still be below 80 degrees and will do it twice before I get out of my neighborhood.
Amstaff is offline
post #4 of 11 Old 01-07-2014, 06:17 PM Thread Starter
Nice Harley Davidson by the way mine is an 04 Harley.
Amstaff is offline
post #5 of 11 Old 01-07-2014, 06:37 PM Thread Starter
Oh and the first two transmissions didn't do the relearn thing or when its cold.
Amstaff is offline
post #6 of 11 Old 01-07-2014, 06:49 PM
Quoted: 2 Post(s)
so, yours has a stock converter in it now? with a built trans? if thats the case, thr issue might be the
pressure spring in the pump, andy puts a spring in it to allow higher presure to the converter (a good billet converter will take more psi than stock). just a thought, but who knows.
I am just about to send my patc converter back to patc and argue for a refund. my converter felt like crap from them, it was very loose, built up tons of heat. im amxious to really get a feel for the PI in comparison. ..maybe ill make a comparison thread between torque converters with some videos I took.
anyway good luck, I am curious to see what it is.
Under construction
Machining the 6.0:
post #7 of 11 Old 01-07-2014, 06:56 PM Thread Starter
Get the patc one out soon or it could take the whole tranny out, mine was the same way yours is. I have PI in it now and I could tell a big difference.
Amstaff is offline
post #8 of 11 Old 01-08-2014, 05:42 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Its not in the tuning then, have you tried swapping solenoids to see if that has any effect on it?
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #9 of 11 Old 01-08-2014, 08:49 AM Thread Starter
Yeah I know that what you highlighted isnt tuning, but the other issues I think are a little of both. No i havent swapped solenoids because they should be brand new the last tranny is only 6 months old and has done it since day one, but the first two didnt do it at all. I am now thinking about trying different solenoids but Im not sure which ones are for what gears.
Amstaff is offline
post #10 of 11 Old 01-08-2014, 03:59 PM Thread Starter
Thought I put this in my post but I guess not. Can somebody tell me which solenoids shift what gears? I seen pictures that say intermediate and direct clutches but not sure what gears are what.
Amstaff is offline
