SCT will not power on - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 13 Old 01-07-2014, 01:43 PM Thread Starter
Oilylizard's Avatar
I thought my OBD2 port was dead, but I have 12v at pin 16, my fuse for obd/cig lighter is good, and my edge CTS will power on. I've talked to SCT and they are stumped. I have plugged my SCT into 2 other vehicles and they power the device on. The SCT is model X3 3000. Anyone else have this problem before or have any thoughts?
2005 F-250 4X4
Harley Davidson Edition #00902
Leveled, Sinister Egr Delete, Studded, Sinister Coolant Filter, Rotella EC1 Coolant, 58v FICM, 6.4 Banjos, Blue Spring, SCT Tuned by Innovative, TSD
and the Wildman, Edge CTS W/ EGT Probe, 4" Turbo back straight pipe, CCV mod, 08 Tails, 08 Pan and filter, 08 Rear Diff Cover, 03 whistler
Oilylizard is offline
post #2 of 13 Old 01-07-2014, 08:24 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The only thing I can think of is the truck OBDII port. Maybe the female pins are stretched too far to make a connection, or the pins on the SCT plug is worn thin.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 13 Old 01-08-2014, 06:22 AM Thread Starter
Oilylizard's Avatar
I have no idea whats going on. My SCT will power on with other vehicles. And if I plug in an OBD2 scanner or my Edge CTS it will power up in my truck. I guess im going to be checking out my grounds in a day or two.
2005 F-250 4X4
post #4 of 13 Old 01-08-2014, 07:10 AM
Heavy_GD's Avatar
Quoted: 1326 Post(s)
I'd run a test light/meter on your OBD11 and visually check the connections.
I had a dirty pin on my livewire, cleaned the pins and it worked fine.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #5 of 13 Old 01-08-2014, 08:14 AM Thread Starter
Oilylizard's Avatar
Did that and everything checks out, man I'm running out of things to look at. I had the passenger inner fender out the other day and thought maybe I messed up a ground, but I just checked chassis ground on OBD port to neg on driver battery and had continuity so I guess that cancels out an open ground. Bummer
2005 F-250 4X4
post #6 of 13 Old 01-08-2014, 08:15 AM
Heavy_GD's Avatar
that sucks... electrical demons are a real PIA.
The only other thing I can think of is maybe you see 12v but the amps are low... but that is a long shot. Sorry.
GD
Heavy_GD is offline
post #7 of 13 Old 01-08-2014, 08:48 AM Thread Starter
Oilylizard's Avatar
This is really stressing me out. I have had this tuner since 10/12 and it's never let me down. I have my truck loaded with Tonys X tune right now and it's the bees knees, but I need to pull a trailer next weekend and might be SOL.
2005 F-250 4X4
post #8 of 13 Old 01-11-2014, 07:48 AM
check the fuse for the power point as well. I had a blown fuse in both the cig and power point and my OBD2 starting working after I replaced both. It's probably not the solution but it's worth a shot.
Heavy_GD likes this.
Roush97 is offline
post #9 of 13 Old 01-11-2014, 06:01 PM
eddie06f350harley's Avatar
its a 20 amp fuse, look under the dash and look for a burnt 20amp fuse,
eddie06f350harley is offline
post #10 of 13 Old 01-13-2014, 02:54 PM Thread Starter
Oilylizard's Avatar
Fuse is good. Read the post.
2005 F-250 4X4
