The NEW MTW Stage 2 - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 33 Old 01-06-2014, 09:32 PM Thread Starter
Dirty_Stroke's Avatar
The NEW MTW Stage 2
Alright guys I'm not very good at reviews but I swapped out my Hybrid with a billet single plane wheel for the new stage 2 with a dual plane billet wheel. I haven't had a chance to get the tunes revised yet but my first impressions are.... Wow!! I didn't even reload the tune, just swapped out the chargers and took for a small test drive last night. It was sleeting outside so I couldn't really get on it but the lag is VERY minimal even with the same tunes. Today the roads were dry and I could play a little. This turbo lights off QUICK!! I done a little "test" on a road near my house (closed course lol yea right) and with my Hybrid, I could stab it from a stop at the light and it would get to 97-98mph when I got to the bridge. Today with the stage 2, I stabbed and it spun 1-2-3 and grabbed and buried the speedo past 100mph about 30 feet BEFORE the bridge! I know that's not very scientific but def shows an increase in top end power. Here's a small video. Keep in mind that's with the old tunes. Listen close and you will hear it bark 5th when it shifts haha.
I will get some more videos tomo
Here's a video from 40ish to 90mph with the hybrid for a comparison. Video length shows 2 seconds longer to get there than the Stage 2.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #2 of 33 Old 01-07-2014, 05:11 AM
Man that's great to hear. I'm running a Hybrid right now and am waiting for Adrian to get me my Stage 2. Hopefully it won't be too much longer! What other mods are you running?
YFZ_53 is offline
post #3 of 33 Old 01-07-2014, 08:43 AM Thread Starter
You can see my sig for all the mods, but main performance mods are 155/stock injectors, MTW stage 2, SPD tune, Herc ficm tune, S&B intake and exhaust. Naturally with all the supporting mods.
post #4 of 33 Old 01-07-2014, 09:09 AM
peixinho's Avatar
Quoted: 191 Post(s)
Glad you like your new turbo! You can see a big difference in the videos!
Sounds like a great improvement over the hybrid! Good Job Adrian!
Dirty_Stroke likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is online now
post #5 of 33 Old 01-07-2014, 09:12 AM
Quoted: 356 Post(s)
Feedback Score: 5 reviews
Dang it... now i'm even more tempted to try out the stage 2..
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
post #6 of 33 Old 01-07-2014, 09:17 AM
strokin6L's Avatar
Quoted: 3 Post(s)
The stage 2 has the .72 compressor housing right?
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #7 of 33 Old 01-07-2014, 10:41 AM Thread Starter
That's a question Matt or Adrian will have to answer. I can say it's for sure an upgrade to the hybrid. And the hybrid didn't run bad on my truck. I can't wait to get the updated tunes from TSD.
post #8 of 33 Old 01-07-2014, 10:44 AM
peixinho's Avatar
Quoted: 191 Post(s)
^^^^ no it does not
KC Turbos
post #9 of 33 Old 01-07-2014, 11:27 AM
madpowerstroke's Avatar
Charlie is right, the new stage 2 has a .58 a/r, the differences are the. Compressor wheel, and turbine wheel along with a small tweak, here and there.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #10 of 33 Old 01-07-2014, 11:10 PM
turbotibbo's Avatar
Subscribed
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
