$7K to spend HELP ME - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 29 Old 01-06-2014, 01:12 PM Thread Starter
COONASS
WHAT HAPPENED's Avatar
Talking $7K to spend HELP ME
So i sold my other truck now I have 7k to spend...
New to me truck 2005 6.0 CCLB FX4 (BONE STOCK) 98K
1. ARP studs
2. Live wire 5051 (what tunes?)
3. 5 inch Exhaust (what one?)
3a Intake??? (I know the 500HP thing)
4. Hostile Rims (Asphalt) 18x9 or 20x10 not sure yet....
5. Toyo ATII's 35x12.50x?? XT
6. Power step (for the wife)
7. ?$?$?$?$?$?$?
2005 CCLB FX4
ARP, EGR Delete, 5 inch TB, SCT Livewire, Sinister Coolant filtration, ECL-1, PHP TUNES
Federal Ownership Respectfully Declined
WHAT HAPPENED is offline
post #2 of 29 Old 01-06-2014, 01:34 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Wow, your off to a good start. A stage one turbo with a billet wheel, php ficm tunes would increase throttle response, sct custom tunes such as quick tricks looney, Tony wild man tunes, php, tsd spd just to name a few. Tunes really depends on what you are trying to do tow, race, or dd. In reality it easy to spend 7k especially doing studs depending what all you have to replace as far as dummy plugs, stand pipe, banjo bolts, blue spring update, sct fitting, or possible head problems.
You would be surprised what a stage one and ficm tunes can do for your rig stacked with a custom tunes. It would be a completely different truck. Good luck.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 29 Old 01-06-2014, 01:40 PM
Java's Avatar
Don't forget about an egr delete.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #4 of 29 Old 01-06-2014, 03:20 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Depends what you want to do with it. Studs will soak you about 5k. then I would flush coolant throw in ELC, get a coolant filter, delete the EGR, FICM tune, SCT tuner with Gearheads tune, oil bypass, Flo-pro 4 or 5" exhaust ( comes with a TRUE 4'' DP unlike other brands and also comes with the best exhaust clamps out there. They are a band clamp versus the pinch style clamps ). If you have money left, post back ahha
MrOneEyedBoh is offline
post #5 of 29 Old 01-06-2014, 04:43 PM Thread Starter
COONASS
1. ARP studs
7. ?$?$?$?$?$?$?
1. (What im getting so far) $3,500 installed
EGR Delete Kit
Ford OEM Head Gaskets 18mm
Ford Factory Exhaust Gaskets
ARP Head Stud Set
New Factory Oil Cooler Kit
New Factory Oil Cooler Screen
Ford Factory Intake Gaskets
Ford Factory Turbo Hardware/O-Ring Kit
Ford Factory Valve Cover Gaskets
Valve Cover Grommets
Valve Stem Seals
Injector O-Ring Gasket Kit
Air Pump Gaskets
Air Sensor Gaskets
Cylinder Head Gaskets
Cylinder Head Plugs
Fuel Filter Gasket
Fuel Filter O-Rings
Fuel Pressure Regulator Gaskets
Oil Filter Gaskets
Oil Pump Cover Gaskets
Oil Pump Inlet Gaskets
Oil Pump O-Rings
Throttle Body Gaskets
Coolant Flush to CAT
What im looking at...
2. Live wire (~$499) tunes $$$
3. 5 inch exhaust (~$400) Flo-Pro???
I will do the blue spring my self when i get the truck back from the shop...
The truck is going to be my DD but i do want HP and TQ with a great shifting tune.....
2005 CCLB FX4
post #6 of 29 Old 01-06-2014, 04:48 PM
peixinho's Avatar
Quoted: 238 Post(s)
I would not get the livewire... and I have one... If i did it over again I would get a normal sct 3015 tuner and then and edge monitor.
It will cost a little more but I think the edge is a much better monitor. Also if your monitor ever gets stolen then you still have your tuner.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #7 of 29 Old 01-06-2014, 05:02 PM Thread Starter
COONASS
That is true but can't you "un-plug" it and take it inside every night...
2005 CCLB FX4
post #8 of 29 Old 01-06-2014, 05:06 PM
peixinho's Avatar
Quoted: 238 Post(s)
very true but who unplugs it every time... at the store... at work...
Not going to try and talk too negatively about the livewire... but... the touch screen SUCKS!!! It does not read all the sensor like the edge, torque, or dash boss. I believe the pyro sensor is more expensive. Oh and if you have problems (like me) and have to send your livewire back to sct then you will be without your tuner and you monitor for up to 3 weeks
KC Turbos
peixinho is offline
post #9 of 29 Old 01-06-2014, 05:14 PM
Gearhead2012's Avatar
Quoted: 3 Post(s)
what, are you gon a sleep with it under your pillow and hope the horsepower fairy leaves some injectors under your pillow? lol. im kidding, but yeah i wouldn't want to plug and unplug it all the time.
I too have a livewire ts. its ok...and, just that...ok. not great, not terrible...although ive been ready to throw it through the window a few times. the screen is very touchy, and it doesnt monitor as much as the edge insight cs/cts does, but I think the edge stuff costs more to add the extra sensor stuff onto.
if you have an iphone get dashboss, its like 150 bucks or so, and monitors everything the edge does, you obviously also have to buy the egt probe and all that (ps...while your heads are off, drill and tap your exhaust manifolds for the egt probe, so as not to worry about metal shavings in the turbo). I dont have an iphone...or dashboss, but everyone with one seems to love it. id recommend a coolant filter, if you dont get the bullet proof diesel oil cooler.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #10 of 29 Old 01-06-2014, 05:20 PM Thread Starter
COONASS
Thank you guys for all the input...
Im going to look into the edge (for the first time) right now...
2005 CCLB FX4
