Injector R&R Going Back In - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 01-05-2014, 07:22 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Got my set of remaned set of 175/75's back from Jess yesterday Complete with the new White High Power Spool Valve Coils! no additional cost, just a Merry Christmas Note! Now that is taking care of your customers.....
I have the Drivers side in and all buttoned up.. Tq'd the Injectors to 31 Lbs per Jess. The Oil Rails to 120 In Lbs. and the Dummy Plug and Stand Pipe to 60 Lb. I may have over done the Dummy Plug afterwards I read where it should get 39 Lb not 60 but nothing broke so we'll see.
I have the Passenger's side in, 1 & 3 Tq'd and have to modify my T40 and use a 10mm socket to do #5 & 7 so they will be done tomorrow.
Got the Sin. Diesel Ceramic Y- Pipe in and all connected up thanks in part to all the instructions shared on this site.
So far I haven't had any extra parts and everything on the bench has a place to go.
With any luck I may have it running tomorrow evening, wish me luck.
Jess wants me to post a video of the injectors starting in the cold and states i could run any weight oil and should never experience stiction again with these new HP spool valve coils.
My only regret is that I didn't have the funds to do a ported intake, so that have to be the next upgrade.
Jess went far and above to get these injectors to me and lost money to ensure we on the forum are taken care of, i couldn't be more satisfied.
Thanks again to everyone that provided insight and direction.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 11 Old 01-05-2014, 07:24 PM
JGman141's Avatar
Jesse is a great guy to work with and I can't wait to hear how the new spool valves do.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 11 Old 01-05-2014, 07:29 PM
madpowerstroke's Avatar
Glad to hear, Jesse is the best.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #4 of 11 Old 01-05-2014, 07:47 PM
Scolesy8's Avatar
I think it would be nice to have two identical sets, one with the new HP solenoids and one without as kind of a side by side to see exactly how much of a difference they make. had talked to Patrick about them the other day.... throwing the idea around yet...
Zach
'04 F250 6.0 with some go go
Scolesy8 is offline
post #5 of 11 Old 01-06-2014, 08:51 AM Thread Starter
Quoted: 2 Post(s)
Do you have any idea how difficult the installation of a full set can be?
There is no limit of things that can go wrong or get missed and end up with a blown motor, the oil rail bolts on the passenger side and rocker cover bolts on the back are enough to make you drink.
My injector cups are surgically clean, Torqued every bolt and nut with 2 different Tq. wrenches. Verified every nuance of every Injector.
I can't mentally or physically go thru this again, but of course I would if it needs it.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #6 of 11 Old 01-06-2014, 11:44 AM
snafu!'s Avatar
Denny the stand pipes and dummy plugs are suppose to be torqued to 60 ft/lbs, the 6.0 bible lists that torque value wrong. I went off the 6.0 bible and ended up pulling the passenger side back apart and retorquing them.
What is different about the new spool valves and why are they so much better?
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #7 of 11 Old 01-06-2014, 02:14 PM Thread Starter
Quoted: 2 Post(s)
What 1st start procedure should i follow?
Crank with relay out for 20 seconds or so 2 - 3 times using the under hood starter activator wire?
Or crank as usual until air is purged naturally?
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #8 of 11 Old 01-06-2014, 02:18 PM
04cr450's Avatar
just crank it.. use 10 second intervals.. Should crank over after a couple tries
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #9 of 11 Old 01-06-2014, 03:40 PM Thread Starter
Quoted: 2 Post(s)
Last question will the stand pipe reconnect with the oibg pipe once I start tqing or do I need to fish it out. 1 side came out the pass side stayed in.
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #10 of 11 Old 01-06-2014, 04:36 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
yes the check valve will mate up with the long stand pipe just fine. There's really no way you can miss it.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
