Sway bar bushing replacement, help. - Ford Powerstroke Diesel Forum
Old 09-06-2008, 09:11 AM
I am replacing my worn sway bar bushings with Energy Suspension polyurethane bushings 4.5186. The new ones look nothing like the factory ones, is that right?
How do I remove the factory bushings for the drop down links, eyes (or whatever they are called)?
And the longer, top bolts, don't fit all the way into the new steel inserts.
Old 09-06-2008, 01:55 PM
don't bother trying to take the bushings out yourself unless you have a hydraulic press...it's not worth the effort. Just take them to your local mechanic and get them pressed out.
don't know about the bolts though. maybe try to compress it a bit with a c-clamp?
Old 09-06-2008, 05:16 PM
Peei,
Did you install the energy suspension bushings? The factory bolts have a taper, that is they are larger diameter near the head and do not go in the steel bushing.
Old 09-07-2008, 04:37 AM
yep...and that's magnum to you
You just have to pound the bolts in with a hammer, same way you would have removed them from the factory bushings.
Old 09-07-2008, 06:17 AM
Can I drive without the sway bar? So I can get the bushings pressed out.
Old 09-07-2008, 06:36 AM
of course...just don't take corners really fast and tight.
and just another tip - I had to try two places before i could find someone to do it, we couldn't figure out how to hold the link in place. The best way to press it is by using a large impact socket under the end link to hold it in place, then press out the bushing with a smaller socket, like so:
Old 09-08-2008, 05:32 PM
Nice drawing! I dropped off the links at a shop and picked them up tonight. I just got done putting it back together, but thanks to the ****ty instructions I don't know where the 4 washers go. i put one on each bolt first, one washer on the head side of each link, is that right?
Old 09-09-2008, 06:03 AM
that sounds right. the washers are used so the bolts aren't tightened directly on the bushing.
