Spartan Tunes - Ford Powerstroke Diesel Forum
Old 09-04-2008, 05:10 PM
Spartan Tunes
Ok, so I hear that DJ's is not doing custom tunes right now. So doing some looking around I found Spartan Diesel. They have several custom or semi custom tunes for the 04 6.0l that I run. So what can yall tell me about them? Anyone using any of these tunes right now and what kinda results you getting out of them?? I know Innovative diesel tunes are very good also!!
Thanks,
Old 09-04-2008, 05:25 PM
Almostdunfukinwidit
The spartan tunes are ok. Just make sure you go in and set your rear axle ratio, and revs per mile so it shifts right
Old 09-04-2008, 07:07 PM
they aint bad for free but they DON'T compare to extreme street. i love my tune from eric. i thought spartans shifted to soon and the egt's got up there quick if you went with the hybrid race tune, smoked good though. i did like the agressive street economy. got me 19mpg.
Old 09-05-2008, 08:41 AM
Send a message via Yahoo to 06ARMADILLO
I run the Hybrid Race tune in my 2006. I really like it. Make sure that you set all the parameters correctly as previously stated. The power is great, smoke is decent, throttle response is great. I haven't exceeded 600* EGT, and have swung the needle past 100mph several times. This tune does NOT run hot for me.
Old 09-05-2008, 08:47 AM
Almostdunfukinwidit
Where is your pyro mounted, pre or post turbo
Old 09-05-2008, 08:53 AM
My pyro is mounted pre-turbo. Best case would have been to mount 2 probes, but it was hot as hell in the driveway that afternoon. Call me lazy.
Old 09-05-2008, 08:54 AM
Almostdunfukinwidit
Pre turbo is good. I was just curious because you said you only hit 600 degrees with the Hybrid race tune. You must not have been in it too long
Old 09-05-2008, 08:57 AM
Rob Rob is offline
spartan tunes are ok. my truck didnt like them too much. mainly the shifting....
Old 09-05-2008, 09:00 AM
Send a message via AIM to 67ModStang Send a message via Yahoo to 67ModStang
I pull out of the driveway and hit 600*
You must mean 1600*
Old 09-05-2008, 09:06 AM
Nope, my truck NEVER runs hot. Highest EGT I have ever ran after installing the probe was towing a 12,000lb trailer south I-65 through the Tennessee mountains at speeds exceeding 100mph. EGTs barely crested 1,100*.
I checked trailer weight on a semi-truck weight scale on the interstate*
Luckily, the truck never runs hot.
