Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 09-04-2008, 07:54 AM
panicattack3636 panicattack3636 is offline
Replacement Turbo
I am replacing the turbo, and am looking at the turbotecnics. Has anyone replaced the turbo in their 6.0? Has anyone had any luck with anything else?
Old 09-04-2008, 08:00 AM
shu873 shu873 is offline
hillbilly keyboard racer
If you're going to switch to a non-vgt replacement, the edge mod. in your signature will be worthless to you. You'll need a custom tuned SCT to make it work. Eric at Innovative is right in your back yard, I'd give him a call.
Old 09-05-2008, 10:09 AM
galoush galoush is offline
I had the same question , as far as it not working with the Edge or whatever could you clarify whey that wouild not work ? .........Im a turbo guy from the Buick Grand National Gang and im confused as to how that would be the case
Old 09-05-2008, 10:15 AM
07stroker 07stroker is offline
I wanna go fast!!!
Are you going to put larger injectors?
Old 09-05-2008, 06:20 PM
I wansnt planning to myself .....i just was interested in the turbo being more Responsive and more consistant than the stocker .......im trying to sell my truck but if it dosnt go i may do it down the line , lift and some diff tires .
Old 09-05-2008, 06:25 PM
Dusty's Diesel Dusty's Diesel is offline
The TN kit comes w/ a bracket that holds the variable vane selanoid closed, That way the truck thinks it is still there, Then custom tunes tune the truck for a coventinal turbo instead of a VV. I would never go back to VV turbo's.
Old 09-05-2008, 06:52 PM
So other than it throwing a code im assuming any issues with it not tuned for that , whats a good turbo to consider for a stock type replacement i was looking at the Turbonetics one and ATS Aurora 3000 . The TN kit im assuming you mean Turbonetics i belive just holds the soliniod to keep it pluged in heres the Install instructions fo anyone whos interested http://home.mchsi.com/~f350/6.0instructionkit.pdf
Old 09-05-2008, 07:13 PM
I have the exact turbo for sale on here that you need for a modded stock truck, or you could switch the exhaust housing for 190cc injectors. Look up under my sponsor forrums and you will see the thread. it is a ausome deal. I have never heard of any one doing a aroura 3000 on a sick o before. Probably would work good to.
Old 09-05-2008, 08:23 PM
I dont think ill be doing it to soon $$$$ you know , hopefully the truck will sell but if the Vette sells first i may end up doing one down the line , i checked out your turbo decent deal if i had the Funds . Toys i got hard cash i dont ..............
Old 09-16-2008, 07:20 AM
O.K. so I have the new turbonetcis turbo installed and it runs alot better. But it seems to be holding back. Is this why I need to install the SCT. Is the Edge trash now? Can I do the SCT and tuning myself?
