One piece driveshaft???? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 08-31-2008, 04:56 PM Thread Starter
outrage's Avatar
I had my two piece driveshaft replaced with a one piece. I had my truck lifted 6.5" and they could not get the vibration at take off to stop. I was told a one piece driveshaft would fix the problem,so I did it,and this fixed the vibration.Just wanted to know if anybody has had any problems after doing a one piece driveshaft?
Terry
2004 Ford 6.0 F-250 Lariat PSD FX4 4X4
Airaid cold air kit
Pro Comp 6.5" lift
20X9 Chrome Incubus Nemesis 8
325X60X20 Kumho Tires
Dual Stabilizer shocks
HID Headlight and Fog light 8K
Sct X3 (X-Street)
Extreme street tune from Innovative diesel
MBRP 4" turbo back exhaust w/5" Tip
EGR delete
ARP Head studs
Zoodad mod
outrage is offline
post #2 of 16 Old 08-31-2008, 06:16 PM Thread Starter
outrage's Avatar
anyone................. back too the top..............
Terry
Airaid cold air kit
Pro Comp 6.5" lift
Sct X3 (X-Street)
EGR delete
ARP Head studs
Zoodad mod
outrage is offline
post #3 of 16 Old 08-31-2008, 06:22 PM
OneTon's Avatar
Mine is stock ... but I would like a one piece ... lose less HP !
2008 Ford F-350 FX4
2006 Ford Mustang GT Coupe
1995 Ford F-150 XLT
1993 Ford E-350 XLT Clubwagon
1992 Ford E-150 XLT Clubwagon
1989 Ford Mustang GT Conv
1989 Ford F-250 XL
1981 Ford Bronco XLT
OneTon is offline
post #4 of 16 Old 09-01-2008, 12:11 AM
AFBLUE's Avatar
why really do they use 2 piece driveshafts? Life would be so much easier if it was just one, even if it was 9ft long.
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #5 of 16 Old 09-01-2008, 12:13 AM
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
I am lifted pretty big and I have vibration but it comes from the front. and its not that bad. done a 2000 mile and a 330 mile trip on it without it bugging me... then again its my truck so i dont care. i think the vibration would bother other people alot. I just know that nothing is lose cuz I built it lol
Class of Aug 17, CFD
lifewitlooie is offline
post #6 of 16 Old 09-01-2008, 01:36 AM
charlesrf600's Avatar
Send a message via AIM to charlesrf600
is your truck lifted with springs or blocks in the rear??
What you need to look at is the agles of the ujoints on the front and rear of the shaft. If I remember correctly they should be very close to the same angle. you may have to use some wedge shims on the rear axle to get the angles correct and that should get rid of it. I had to do this on an old jeep. lifts are designed around the 2 piece shaft and only correct for those angle and even then some do better then others. but hey this is just my 2 cents.
hope this helps
Leveling kit
35" Nittos
Bushwacker cutout fender flares
5.9 12V Cummins Swap (In progress at Twisted Metal)
Future mods
King coilovers leveling kit
bedcover, custom bumpers, racks
charlesrf600 is offline
post #7 of 16 Old 09-01-2008, 01:51 AM
COLLEGE KID
a block and one add-a-leaf in the rear.
where do the shims go? I only used shims once and that was helping someone put new gears in a 89 wrangler. its tough!
post #8 of 16 Old 09-01-2008, 02:04 AM
They would go inbetween the axle and block. If you have a flat block you could look for one that has an agle built into it as well.
Here is a link to the shims Driveline Alignment Shim Kit
and a pic of where they go
Leveling kit
35" Nittos
Future mods
post #9 of 16 Old 09-01-2008, 02:20 AM
COLLEGE KID
interesting! i didnt even know those existed.. thanks bud
post #10 of 16 Old 09-01-2008, 02:33 AM
Other vehicle is an F250
Hank's Avatar
I have a 6.5" lift also. The center carrier bearing was shimmed down at the time of the lift (previous owner) and was not a problem until I added a TW chip. The new HP showed up several weaknesses in the old girl. I found that my carrier bearing was worn - replaced that and still had a little chatter on take off. Made a couple of 3/16" shims yesterday and added them. The additional 3/8" has almost cleared up the problem. I can still feel a little vibration. It may be the U-joints?
My rear shaft is within 1 degree of being the same as the pionion shaft angle. The two shafts are within 2 degrees of each other now. It is hard to determine the angle between the output shaft of the transfer case and shaft.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
