EGR DELETE W/MANIFOLD MODDED
OK GANG!!! We have discussed this EGR and SMOKE issue till I'm Smoked In The Face
![]() Here It Is: Head Studs Installed, Up Pipe Blocked Off, EGR Valve Welded Shut. I'm Blowing White-Grey-Blueish Smoke Again. Didn't pull egr valve to see if saturated.....I'm sure it is. Loosing coolant little by little ![]() OK: what is BEST DIRECTION GANG?? Another EGR Cooler or total DELETE Innovative has this manifold 6.0L EGR Cooler DeleteAnybody use one of these? LOOKING FOR TIPS, ADVICE, HELP |
I am still stock but when mine goes I will delete it.
Let's see/hear your best EGR DELETE
I'de say if your mechanically incline do the EGR delete yourself and save $600. It's not the hard. Weld the up-pipe shut, cut the flange off the cooler plug the hole then bolt it back on the intake and then re-route the coolant hose.
your blowing blueish white smoke...
are you sure its a EGR cooler and not a Oil cooler. by all means do the egr delete but....it may or may not solve the underlying issue which could be a oil cooler. |
Up-pipe is welded.
I guess my question is has anybody had a problem with this mod. Any of those "U" hoses blown as explained in Inovatives web?? |
If you don't like the U hoses you can always get a U shaped aluminum tubing.
No smoke at all when engine is cold. After 2-3 miles the cloud appears. HEAVY!! I get off the highway after running 15 miles and the smoke clears up a lot. Still there though!! When I first accelerate ......Cloud Appears |
Is there anyway that coolant can be leaking by the injectors?
