Fuel Pressure Mod? - Ford Powerstroke Diesel Forum
Old 08-29-2008, 10:55 AM
Feedback Score: -1 reviews
Fuel Pressure Mod?
What exactly is this mod? I've searched but no luck! What are some of the advantages of it?
Old 08-29-2008, 11:15 AM
It's not really worth the time. Get a RR system.
how to shim the regulater - The Diesel Garage Forums
Old 08-29-2008, 05:01 PM
So i looked at the link and where does the ferrel go? In between where?
Old 08-29-2008, 05:06 PM
I would love to do this but, don't have or want a FP gauge.
Old 08-30-2008, 11:04 AM
The BB goes under the spring inside the brass plug....
Old 09-12-2008, 05:52 PM
Ok well i put on a guage on the truck and i see 60psi at idle and when i get WOT it goes down to 25 pounds. Its weird the truck doesnt fall off when the pressure drops. Now i ran the truck on diesel and my Bio mix and i have the same results. Any Ideas? DO i have to bleed any air out of the gauge line? Could it be air in the line causing the drop in pressure?
Would the REG Mod fix this?
Old 09-13-2008, 06:39 AM
Anybody???
Old 09-13-2008, 07:43 AM
if you're running a hot tune, it's simply that the stock fuel system can't keep up with the demand the tuner is calling for...
time for for a FASS150/180....
Old 09-13-2008, 08:12 AM
But im running DJ's Looney Tune
Old 09-13-2008, 09:06 AM
run it with stock tuning and watch the fuel pressure...if you're still seeing a big drop, then check your fuel filters to see how dirty they are....if they're good, your FP may be getting weak...
