up pipe scoop removal???? - Ford Powerstroke Diesel Forum
post #1 of 29 Old 08-28-2008, 03:07 PM Thread Starter
jcmer22's Avatar
can someone explain how to get the scoop out. what kind of tool will fit in that passage to cut it out? seems to me the only way is cutting the "t" out and patching it but i wanted to make a sneaky pipe out of my extra up pipe. any suggestions? thanks, john
jcmer22 is offline
post #2 of 29 Old 08-28-2008, 05:34 PM
scotty2280's Avatar
i cant really help u out there but thats a nice looking truck u got there, im a fan of the reg cabs
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #3 of 29 Old 08-28-2008, 05:41 PM
I tried it with a sawzall and screwed up. I just bought another one and left the scoop in and put blocker plate in anyway. A 03-04 up-pipe will not work on a 05+ motor. I already tried that.
2005F250 is offline
post #4 of 29 Old 08-28-2008, 05:56 PM
The easiest thing to do is just pick up a sneaky pipe. They're not that expensive and save a lot of work cutting, grinding, and welding.
2006 F-250 Powerstroke Crew Cab Lariat Long Bed 4x4 FX4
SCT Xcal2 with Xtreme tunes by Innovative
Banks Monster Exhaust/Quadzilla Commander
ARP Head Studs and Elite Sneaky Pipe (Thanks Scuffy)
tech10002 is offline
post #5 of 29 Old 08-28-2008, 06:24 PM
Rice Hunter
Diesel Freak's Avatar
Lately I have been looking for this sneaky pipe. Forgot who was carrying them
Any Help?
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #6 of 29 Old 08-28-2008, 06:36 PM Thread Starter
jcmer22's Avatar
thanks a lot i really appreciate it.
Any Help?
i think elite diesel does however i bought a brand new up pipe from a member for only 75 and i could cut out the "t" and get a plate welded in there for cheap im assuming and i think a sneaky pipe is $165 and the up pipe egr delete pipe is $220 so i should save a little and i can keep my factory one just in case.
jcmer22 is offline
post #7 of 29 Old 08-30-2008, 12:08 PM
What is the difference between the EGR Delete pipe from Elite Diesel for $220 and the sneaky pipe for $165.
Is the Egr Delete pipe the entire Delete?
Is there really any more benefit from it?
And is there any more work involved in installation?
sorry for all the ?'s im looking to buy on or the other
2005 F350 FX4 CC LB LARIAT 6.0L Diesel -SOLD
2012 F350 4X$ CC LB LARIAT 6.7L Scorpion
BLACK and ADOBE
RECON Lights
LEVELED.........My Black Stocky!!!!
Adamvabeach is offline
post #8 of 29 Old 08-30-2008, 12:50 PM
!!!PainTrain!!!'s Avatar
The EGR Delete Pipe is NOT a complete EGR Delete kit. The difference between this one and the sneaky pipe is simple. The sneaky pipe still retains the the exhaust pipe extension, which still allows exhaust flow into the egr cooler.
This is called the sneaky pipe because from the outside it looks just like the stock piece.
The EGR Delete pipe has that extension removed so exhaust does not flow into the cooler. This does not look like the stock pipe and the dealership/tech would beable to recognize this right away.
As far as I know there is no difference in the installation time or diffiulty wise.
Here is the link to Elite Diesel that shows the difference between the two pipes in question. Hope this helps ya out. 6.0L EGR Components
Performance: SCT Xcal-Innovative Diesel, 4" Turbo Back Exhaust no muffler and kitty missing, Spearco IC, ID Power Elbow, AFe Stg. II Intake, 03 Turbo.
Exhaust Clip:
Looks: Westin Black Powder Coated Bull Bar, Recon Smoked Cab, Mirror Lights, and 3rd Brake Light, 4" Superlift kit, 35" ProComp Extreme A/T's, 18x10 Diamo Black & Chrome Rims.
!!!PainTrain!!! is offline
post #9 of 29 Old 08-30-2008, 12:53 PM
I thought the sneaky pipe had the T portion blocked off, though, so no exhaust gas can pass through the EGR cooler. If it still allows some flow, I can't see what good it would do to install it. Is that not how it works?
post #10 of 29 Old 08-30-2008, 12:56 PM
Straight from the elite website:
Up-pipe with Blocked off EGR (Sneaky Pipe)
$165.00
Want to block off the EGR on a 2005 and newer truck that has the restrictive scoop shown below? Here is a replacement up-pipe that does not have the restrictive scoop, so you can use the included block-off plate. This maintains the factory appearance of your original pipe. Pipe comes with genuine Ford hardware: 4 new fasteners, nuts, and gasket as well as our block off plate. On certain trucks this modification may set a check engine light, our custom tuner can eliminate this condition.
Up-pipe with EGR pipe Delete
$220.00
This is a replacement up-pipe that no longer has the exhaust pipe extension to allow exhaust flow into the EGR cooler. This modification also removes the restrictive scoop found inside most up-pipes on 2005 and newer trucks. This works the same as the EGR plate but improves performance by removing restriction in the exhaust. Pipe comes with genuine Ford hardware: 4 new fasteners, nuts, and gasket. This pipe gives the best flow of the three EGR blocking options. On certain trucks this modification may set a check engine light, our custom tuner can eliminate this condition.
Exhaust Clip:
