compressor surge - Ford Powerstroke Diesel Forum
Old 08-27-2008, 05:50 PM
compressor surge
does anybody having there turbo compressor surging. is it a problem?
Old 08-28-2008, 05:33 AM
Had issues w/ surge when experimenting w/ different compressor wheels/housings. You want to take care of this as YES, it can and likely will cause problems if it happens a lot.
Stay Tuned
Amp
Old 08-29-2008, 03:57 PM
is there any way to avoid this from happening?
Old 08-29-2008, 03:59 PM
a diff turbo will completely eliminate surge.... some people say the ww or a housing helps... im still skeptical of this though
Old 09-02-2008, 05:01 AM
There is a fine balance between tunes, wheels (compressor/turbine) and housings (compressor/turbine) that have to be correctly matched. If one of these factors is off you can get surge. I'd recommend talking w/ a reputable tuner/vendor who has experience dealing w/ the compressor maps of different set-ups. There are several proven combinations out there in aftermarket products.
Stay Tuned
Amp
