next performance mod - Ford Powerstroke Diesel Forum
Old 08-26-2008, 04:04 PM
with whats done in my sig what can i do next to add more power at a reasonable cost. injectors are not an option right now.
Old 08-26-2008, 04:28 PM
Fuel pressure mod. requires a BB to tweak your fuel pressure just a bit....really useful for protecting your injectors when running hot tunes. I used a Bobcat part # 6592105.....costs about 15 cents and will get you 60-65 psi fuel pressure.
Old 08-27-2008, 11:46 AM
How about a spearco intercooler to give you cooler denser air?
Old 08-27-2008, 12:12 PM
i think im gonna do a cfm large mouth with the 3 tapped holes and do the snow performance stage 3 mpg-max kit. that will give me more power, add gauges cause of the digital controller and lower egts and be easy to install cause the intake elbow will be pretapped. anyone disagree as this being a good next mod? i want to do things are that easy to change back to stock just till my warranty gets closer to running up. then i can do the injectors and fuel system.
