CAT delete pipe install info... - Ford Powerstroke Diesel Forum
Old 08-20-2008, 11:51 AM
I just got a MBRP 4" cat delete pipe and I am wondering how hard the install is going to be. I have heard rumor that they can be a pain. Any tips before I get rolling?
Old 08-20-2008, 11:53 AM
<-Day Of Fail now SOLD
Just a little hint, cut the down pipe at the bend by the cat. Then the down pipe will fall right out.
Old 08-20-2008, 12:08 PM
if it's just the delete pipe should take less then 15 minutes. 2 clamps, slide the delete pipe in tighten clamps and your done
I already put in a 4" turbo back system that used the stock cat. But I decided it was time to get rid of the kitty. I had just heard that the MBRP pipe can be hard to put in?
Old 08-20-2008, 12:14 PM
2 minutes..........................
Old 08-20-2008, 12:25 PM
Yea it shouldn't take any time at all. Just measure twice and cut once.
Old 08-20-2008, 12:33 PM
If it has been awhile since you put the exhaust in you may want to spray some wd-40 at the joints so everything comes out smoothly
Old 08-20-2008, 12:37 PM
I just used a section of 4" pipe that was left over from a job and cut my 4" Bullydog exhaust/CAT section away and welded that puppy right up in there.
Old 08-20-2008, 01:06 PM
Send a message via AIM to jhaddox
5 minutes max. its simple to do just pull the cat out and bolt this in place. it makes it easier if you take a few hangers outta the rubber slots near it so you can manuver the ehxaust around
Old 08-20-2008, 01:18 PM
you guys don't drink enough when working on your truck if it's only taking that long
