any one seen the bd ccv kit
I've seen it and someone one the site said if the turbo boots aren't blowing apart then you don't need to do the CCV mod.
that looks retarded
why not just do what everyone does and plug the hole in the intake tube and dump it somewhere under the cab for like 20 bucks?!! |
That is a RIP OFF!!! you can do the same thing for next to nothin.
lol exactly what i thought maybe for a $100 or so
While the CCV reroute was easy and accomplished using "cheap" parts, I would be interested in this kit to eliminate all traces of the smell. If it can do that, the price wouldn't scare me at all. Maybe Kyle from XDP can chime in...
PS. Your CAC boots will eventually get oil soaked and then will need to be replaced, but it really depends on how often your truck sees prolonged high boost pressures. |
well here's the deal. even if you are bone stock this is a good upgrade, just b/c your boots haven't blown off yet doesn't mean they wont. and yes while you can do it yourself for $50 bucks, you're not only open venting it into the air but also the ground. the big thing behind this kit is the ease of install and quality look it gives. it's not just a hose dumped onto the ground ya know. this kit isn't for everyone obviously, but for the guy that cares about the look under the hood or doesn't want to mickey mouse something together this is ideal.
I would be intrested just to get rid of the smell as well.... does it collect the oil that drips?
does it collect it... yes in the catch can.
here is the install sheet on it... http://www.xtremediesel.com/manuals/1032175.pdf |
