Alright, First off I have a 05 6.0. I just had the truck head studed with the ARP Head studs. Now I want to have some realiably fun, so what should I do?
For exhaust should I do 4" or 5" and what is the difference between the two?
I agree on the exhaust, but unless you are aiming for high hp numbers save your money. The stock intake flows just fine. Don't get the wrong the AFE is a good intake but why spend the money if you don't need it? The only reason I am running an aftermarket intake is because I have added larger injectors and turbo. You that money you would have spent on the intake and get you some other goodies. Another good mods would be the SCT with custom tuning. If you go with the Livewire you will not need gauges, it has them built in. The key is CUSTOM TUNING! I hope this helps you in your quest for fune and power.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
