A few questions needing answers?.... - Ford Powerstroke Diesel Forum
Old 08-17-2008, 03:43 PM
I currently have the Ottomind with the 6position switch on my 6.0 04 harley truck 250..i would like to add an Edge Programer to "Stack" it? Is this a possibile application and which model would work the best? Also in addition to that is there any forseeable side effects to this combination.
Also is the follow a good combination or overkill?
Airdog Fuel system and Fitch Fuel Catylist System
Also where can i find out the price on the Amsoil Oil Bypass kit for our trucks? I have searched and i can not a find a general price so that i can compare it with the other popular kits out there?
Any and all suggestion are welcomed!
Old 08-17-2008, 04:29 PM
just get sct and be done with it
stacking chips on 6.0 leads to blown trannies and blown head gaskets.
For the price of the edge you could probably get an sct from dj!
Fitch fuel catylist is bs, waste of money.
Airdog depends on what you are doing. Do you have larger injectors, do you want larger injectors.
Probably better off going with FASS since airdog you will also need the raptor pump, where with fass you dont.
Old 08-17-2008, 04:31 PM
So can the SCT work with the ottomind?
Old 08-18-2008, 04:58 AM
You cant stack the 6.0. If you load the ottomind, then try and load an SCT, the SCT will just erase whatever was there and load it's own tunes.
You wouldn't want to stack the 6.0 if you could anyways. It's not worth what little it may give.
Just get an SCT and be done with it like said. Since the SCT will put out much more power than the banks stuff, you can just tell yourself you stacked it and be happy with the extra power.
