Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 08-17-2008, 04:22 PM
gabelnj gabelnj is offline
EGR on an 2004 6.0
Hey guys,
So I purchased my turbo back exhaust, when get home to install it I would like to take care of my EGR. From the research I have done I see that my best bet is to get the block off plate from elite diesel. My question is….drum role.
Who has installed this MOD how easy is it, is there a write up, or pictures. Anything will help because I am learning with this truck.
Old 08-18-2008, 01:33 AM
HeavyAssault HeavyAssault is offline
Find a metal shop, ask if they have any 1.5" SS bar stock (preferred) scrap that they can cut you a 1/4" piece off of. Get the EGR up-pipe out, check for the scoop and remove as necessary, weld in the plug, install the modded pipe.
Now if you want the whole pipe already done up there are some fellas that have the pipes ready to go and will swap you for cash and the core.
I was able to do this in the driveway with hand tools. If you remove the following it helps to access the area: passenger side wheel, passenger side wheel well liner, and downpipe. Have as many rachet extensions as you can find since the upper end of the pipe is hard to reach. Take your time, dont rush.
Old 08-18-2008, 07:01 AM
I have a 04, I should be able to just put the block off plate in and be good to go? From what I have read I don’t think my truck is equipped with a Scoop in the up pipe? What I have read says I can do the block and that’s it, don’t need to worry about CEL or any thing? If this is correct how easy or hard is the installation block plate, and how is it done?
Old 08-18-2008, 07:41 AM
Big Bear Big Bear is offline
Anyone have any pics or step by steps?? I would like to do this too and did a search in the forums and got nothing??
Old 08-18-2008, 10:39 AM
Old 08-18-2008, 12:00 PM
Old 08-19-2008, 02:32 AM
Anyone just a little feed back. Thanks HeavyAssaults for your response.
Old 08-19-2008, 06:20 AM
Evil Eye Evil Eye is offline
Slacker Mod
That's correct. The 03 and 04 don't have the scoop in the up-pipe, so all you need is the block off plate. The CEL will only come up on the older strategies. Worst case, get the latest firmware update from Ford before installing your block off plate so it won't throw a CEL.
Remove your passenger front tire and your up-pipe is just on the inside of your exhaust down-pipe. Remove the bolts holding your up-pipe in place and install the block off plate in the "y" that leads to your EGR cooler.
Old 08-19-2008, 08:43 AM
Thanks
Old 08-19-2008, 08:59 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
an inch and 1/8 feeze plug will work also
