upgraded turbo on 6.0L - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-08-2008, 01:30 PM Thread Starter
06F250powerstroke's Avatar
if i upgrade my turbo do i need to put the head stud kit in? how far can i go with out putting the head stud kit in?
06F250powerstroke is offline
post #2 of 13 Old 08-08-2008, 02:09 PM
Java's Avatar
I went about 4 months before my bolts stretched. what kind of turbo are you gonna put on the truck?
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #3 of 13 Old 08-09-2008, 12:45 PM Thread Starter
was thinkin a black widow or an elite nothing to crazy. how big of a job was it to put the head studs in?
post #4 of 13 Old 08-09-2008, 12:50 PM
Cobra 19 & 54's Avatar
I am bone stock (no turbo upgrade, or injector upgrade,,, yet) with just a programmer. I blew the head gaskets in 3 months. Big job, worth every headache!!!!!!
2004 F-250 FX4 King Ranch, 4" RBP turbo back minus that lousy kitty, s&b intake kit, SCT X3 with Innovative tunes, Elite x-over coolant lines, Liberator EGR Delete, Elite .20 pistons, Elite stg 2 cam, Elite VGT-SS turbo, Stg 3 H2O/ meth, and now I'm broke...
Cobra 19 & 54 is offline
post #5 of 13 Old 08-09-2008, 01:18 PM Thread Starter
wat did it cost do put the egr delete an studs in?
post #6 of 13 Old 08-09-2008, 01:26 PM
$590 for the studs, and EGR delete from liberator $600. Labor was my warranty deductable $100. but I blew the EGR cooler, and that was $425 so they credited that toward the delete kit.
post #7 of 13 Old 08-09-2008, 02:51 PM
jcmer22's Avatar
so you got ford to install the studs when they did the head gaskets?
jcmer22 is offline
post #8 of 13 Old 08-09-2008, 02:57 PM Thread Starter
how did u get them to do all that around here all they will do is replace it with stock stuff that will just break again
post #9 of 13 Old 08-09-2008, 03:14 PM
back in the saddle
shu873's Avatar
Some people are lucky to have good dealerships around that will work with you... I was one of the lucky ones. Others not so lucky and you could spend around $2000-2500 in parts and labor to pay a performance shop to do it for you. This is just a ball park number of course, but it should be fairly accurate. Still well worth it IMO. If you can afford a $2000+ turbo and $1600+ injectors it should be on your "to do list" first.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #10 of 13 Old 08-10-2008, 06:59 PM Thread Starter
so if i do the head stud kit an knock the egr off of it how far can you go with it an still keep your reliability as an every day driver would i be ok with a vgt ss an stage 2 injectors?
