Upgraded Tranny questions
Hey guys, I'm currently running the extreme race tune daily from Innovative. I eventually want to do a bigger turbo and injectors along with headstuds, but if I do that i'm scared that my tranny will take a dump on me. What should is necessary to keep this transmission in one solid piece when running this kind of power? Or am I worried about nothing?
i believe the 5r100 is a much better trans then the 4r100 in its ability to hold power, but id do atlest a torque converter, deep pan, and upgraded cooler, with a valve body increase, to boost line pressure.
What brand of TC?
If you are gonna do anything the converter would be it. the 5r110 will hold 500-550hp in stock form. the cooler is already massive
Suncoast makes good parts for the 5r110.
Biggest problem with that trans is the tuners not knowing how to control the shifts properly. Call and talk to Cale or Brian at BTS...or John Wood on what to do.
Cary |
I have innovative tunes and it doesn't seem to be much of a problem. but randomly she will take forever to kick into over drive?
cale works on 6.0 trans too,i bet,he would up grade your valve body and have a converter for you too.
I'm assuming this is when running the Xtreme Race file. Its normal.
I am looking at saving a little coin for the exact same reason. Approximately how much should I be planning on spending on a solid converter for my truck?
