Water injection
For those if you that are running a water injection system on your truck, or can offer any info. I want to bring my EGT's down, so I'm going to do the Zoodad mod, and would like to do some injection to. My question is: do you control your injection off of boost pressure or EGT, or both? The Coolingmist kit I was looking at uses a boost sensor for activation, but they also offer another it that uses boost and EGT to activate.
TIA |
Depends on what Snow Performance kit you get. Stage2 is boost alone, stage 3 is both boost and EGT's.
I have the Snow Performance Stage III Boost Cooler, and you can set it to run off the boost, the EGT's, or both.
Do you like it ? I'm thinking about putting one on mine and are you getting any better milage with it ?
I know I can get a kit that will allow activation of the water injection using either boost or EGT. My question was: what is the better way to activate? I was pulling my 4runner on a trailer today, and flat pulling my brothers Landcruiser (he ran out of fuel on our way back from four wheeling). It was pretty flat towing for the most part, and my EGT's were running a little high for me, but my boost wasn't very high.
What do you set your boost activated injection on? |
I would go with propane!
How much cooler will it run with propane? I know that I get a 150-200* drop in egt's with the water only injection.
The guy I'm getting mine from says to go with the stage three becouse it is programable and that it will come in whenever you want it to . and I have heard that deisels get the best mileage in the 600 range (they say).
