What wot ICP are you seeing on larger than stock injectors - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-02-2013, 05:06 PM Thread Starter
Adamv7010's Avatar
I'm curious what you guys are seeing for ICP on larger than stock injectors and whose tuning?
I'm running one of Vivian's Looney wilds for 175 stock nozzles and a powermax...at wot I'm seeing 1500-1700 psi.
I've ran everything from stock injectors to 225s in this truck, all on the same OEM pump and with 190/75-225/100 I've seen higher ICP than I do with Vivian's file and 175/stocks.
On the other setups I've used various tuners to include all the big name tuners and have always seen greater ICP than I'm seeing now with 175/stocks.
Does the lack of nozzles make this happen?
Adamv7010 is offline
post #2 of 12 Old 11-02-2013, 05:10 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
That's because she is fooling the ECM to see less than desired ICP to keep the ECM from defueling. You should be watching ICPv. If you have open port injectors you will hold less sustained peak ICP.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 12 Old 11-02-2013, 05:15 PM Thread Starter
Adamv7010's Avatar
That's 1 of the very things I hate about using the live wire vs insight.
There's a few good things it won't read.
Thanks bryan
post #4 of 12 Old 11-02-2013, 05:20 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
No problem bud. Let me know if I can help.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 12 Old 11-02-2013, 05:24 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Thanks bryan
Dashboss FTW!!!
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 12 Old 11-02-2013, 05:25 PM
portcity_gt's Avatar
Quoted: 1267 Post(s)
Adam I just wired the output of my icp sensor into one of the analog inputs on the ts the other day. Its easy to do and you can read icp v that way.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #7 of 12 Old 11-02-2013, 05:38 PM Thread Starter
Adamv7010's Avatar
Originally Posted by windrunner408 View Post
Dashboss FTW!!!
im leaning that way nate
Which wire is the output on the sensor? Did you just t tap?
post #8 of 12 Old 11-02-2013, 05:45 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
I completely concur with Nate. Dashboss FTW!!!!!
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 12 Old 11-02-2013, 05:55 PM
This was mine, but its an 03, 05-07 might be different.
Its blue with a green stripe.
post #10 of 12 Old 11-02-2013, 05:56 PM
And yes just tapped into it.
