ICP & ICP VOLTAGE==STOCK VS. TUNED:::PLEASE READ!! - Ford Powerstroke Diesel Forum
post #1 of 32 Old 11-01-2013, 06:02 PM Thread Starter
6 L chevy eater's Avatar
alright guys, i have talked to some of you guys about about my issue with ICP and ICP voltage........ with my performance tune on truck i am seeing 1470 ICP & my ICP voltage is 2.1 @ WOT. i have have been told the that ICP voltage is very lowww. so i returned the truck to STOCK and took anther WOT pull in high gear. on the stock programming my ICP voltage is 4.2 & ICP is 3600+ @ WOT. so ive read so many diff things about this. Does the performance tune fool the system so im gettin FALSE readings on my CTS??? or when the truck is in stock tune are those the true readings??
what im really askin is do i really have a HPO defecincy or is the truck fine with large injectors and stock pump??
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #2 of 32 Old 11-01-2013, 06:20 PM
JGman141's Avatar
Sounds like your stock hpop is going out
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 32 Old 11-01-2013, 06:28 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Some custom tunes manipulate just the ICP psi, some manipulate both ICP psi and ICPv when read thru the OBDII. If the tune writer only fools the ICP psi then the ICPv will be accurate, this will allow you to convert ICPv to true ICP psi. If the tune writer fools both ICP psi and ICPv, then you will need to run a analog gauge "t"d into the HPOP system.
You would need to contact your tune writer to find out which method is used on your tunes.
The pic below is a DashBoss data log of my SRL++ file. The top of column shows the PID. ICPv, ICP psi, and ICP Calc psi. The ICP Calc PID shows what my ICP psi is really reading.
A healthy HPOP should reach just over 4k psi, when maxed out.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 32 Old 11-01-2013, 06:52 PM Thread Starter
sooo first off need to see if tune writer is manipulating both. 2nd, i can data log with edge cts, how do i pull up the info that has been data logged??
3rd, should it maintain 4k+ icp with warren 225/100s? i woulnd expect it too complety even with a stock healthy pump.....
im using eric @ innovatives tuning...... if anyone knows if he manipulates both??
to me it seems to me like he would have too manipulate both becasue 2.1 is LOw and i dont think truck would run well at all with it being that low.
please educate me.. lol
2004 F250 ccsb
post #5 of 32 Old 11-01-2013, 06:59 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
I don't know how well Edge data logs or how to bring it up on the device. I do know Edge won't have the ICP Calc PID.
With those size injectors, you might not be able to hold ICP with a healthy pump, but I'll let one of the "big dog" chime in on that. I only have stock injectors.
Lilpooh is offline
post #6 of 32 Old 11-01-2013, 07:06 PM Thread Starter
ok thanks!! i am jus tryin to figure out if i need the upgrade and if so what is my best avalible option......
2004 F250 ccsb
post #7 of 32 Old 11-01-2013, 07:22 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
By reading your first post, it appears to me that you're maintaining ICP pretty decent with stock tuning but aren't even coming close in the race tune. Probably due to reduced PW in the tune for the stocker. Now it may vary by tuner and by strategy but my ICP V reads just fine when tuned with Eric's tunes. As far as I know, he only manipulates the ICP pressure portion. In all honesty, I don't believe that the ECM uses ICP V. Only ICP Pressure. I guess I said all that to say, I think you need more oil and I don't believe a stock HPOP will do it.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #8 of 32 Old 11-01-2013, 07:28 PM Thread Starter
ok i will double check with eric to see what he says, there a few options out ther to do with a delivery system, dual pumps, ect. whats the best and most efficent route for me to take. would 255cc hybrids change the ball game u think.
or should i jus up the oil some how some way??
2004 F250 ccsb
post #9 of 32 Old 11-01-2013, 07:45 PM
BACKYARDIGAN
Quoted: 4 Post(s)
My opinion would be to just up the oil. The way to do it can be debated. Hybrids kill your injection pressure which is going to reduce the efficiency of combustion.
Nate
post #10 of 32 Old 11-01-2013, 08:47 PM
Quoted: 5 Post(s)
I believe nate is correct the computer looks for a psi and that is the reason most tuners manipulate that number. That allows the IPR to go full open giving you max injection pressure, which is obviously desirable for a lot of reasons.
It really looks like that size injector is not allowing the stock HPOP to maintain pressure while running a performance tune.
I would take nates advice and just up the oil - do not pass go do not collect 200
I have been reading a ton about injectors and injection pressures lately and I am now realizing why common rails make so much power with so little effort.
Todd
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
