Normal temps? - Ford Powerstroke Diesel Forum
Old 07-27-2008, 02:42 PM
Question Normal temps?
iam runing looney every day plus a 4inch straight my temps are. trans 150-165. coolant 190-215. egts 500-750 normal driveing. is this regular for the coolant to run this temp about a month ago my tranny ran 140-150 and my coolant ran 180-190?
Old 07-27-2008, 03:19 PM
that's all normal. Just wait for your coolant temps to go haywire on the commander. Seems to happen to everyone sooner or later. Mine reads from 190 to 250 and bounces all around like a crackhead.
Old 07-27-2008, 03:21 PM
ya mine started goin back and forth from 175 180- 215. all my buddies that road with me few weeks after i had looney installed were surprised my tranny ran only 140 now it runs 160+ most of the time.
Old 07-27-2008, 03:25 PM
DKR DKR is offline
<--Pro Cooler Racer
One of the reasons I dumped my Commander was for that.
In the heat of summer I can easily see upto 168* on my trans if I'm running hard, and averaging 195-203* on the ECT..EOT runs about 5-7 degrees hotter. On a good hard pull I've hit 210* on the ECT.
Now, I do have a busted EGR cooler, so it is probably playing havoc with my ECTs. But, that will be cured soon.
My higher temps I have just seen within the last month, month and a half. We have gone into a heat wave and high humidty over the last couple of weeks.
Old 07-27-2008, 03:33 PM
yea the hottest I've seen my tranny is around 173 and I was stop and go around town driving in over 105 degree heat. God knows how hot it was under the truck between the truck and the road. whew!
Old 07-27-2008, 07:42 PM
yeah thats what i was thinkin all this heat in mid summer probly causeing most of it i know the heat is maken my truck smoke alot more lol
Old 07-28-2008, 09:49 AM
If you have a busted EGR cooler you will see white smoke and the truck will run like you have a plugged fuel filter. Get that fixed ASAP if it is busted or you will be in to the Ford garage giving them $4000 for a head job and you will not like that.
Old 07-28-2008, 09:59 AM
he's already got it taken care of. Also already has studs. Check his sig.
Im assuming that an EGR cooler will not be going back in his truck
Old 07-28-2008, 12:00 PM
Feedback Score: 5 reviews
those temps sound about normal..your temps are hotter now becuase its summer.
under 200* is good for the transmission
under 230* for ECT or EOT
