Injector Opinions- Chime in everyone - Ford Powerstroke Diesel Forum
post #1 of 44 Old 10-30-2013, 04:20 AM Thread Starter
Texas Proud
charlie.thomas's Avatar
Arrow Injector Opinions- Chime in everyone
Ok, all opinions are needed right now on injector sizes. My intentions are I want to go to a 175/75 but I don't know how they would do towing an average load of 15k. The advice that I am looking for is what would be the best size injectors to run to get the best power but also still be able to tow a load often? All opinions count on here lol. I've also had a thought about 155/55 but I do not know what route to go on an injector due to I have always only ran factory because I tow often but I am now wanting to squeeze that little bit more out of my truck
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #2 of 44 Old 10-30-2013, 04:25 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
Without air flow it's a crap shoot. Drop the cash for a single plane Pmax, modded y-pipe and a ported manifold first then add injectors later. Then those 175's will do all you want and keep the EGT's in check.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 44 Old 10-30-2013, 07:25 AM Thread Starter
Texas Proud
I did change the y pipe out while I had the cab off when I was rebuilding the motor. I have thought about an intake before, where would I find the bang for the buck on one? Turbo wise, I have an 03 sitting at the house that I also have a bigger compressor wheel for that I was thinking about building. Thought about trying that before I dump the cash on a pmax since I have all the parts to build one that would be bigger than my factory 07 turbo. Whatcha think, worth trying or no?
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #4 of 44 Old 10-30-2013, 07:35 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I have a few leads on things. Pm me if I can help you figure things out.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 44 Old 10-30-2013, 07:43 AM
N.S.D.Q.
Quoted: 97 Post(s)
Get the 2003 done like you talked about. I think a vendor on here has their ported manifolds VERY well priced and worth it.
post #6 of 44 Old 10-30-2013, 07:47 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
Having run both 50% and 75% nozzles I would not use 75s on a vehicle that will be towing what you are requesting in you first post, regardless of the turbo. If the load was <10k without steep grades then I would say do it, but realize 30%-50% would more than enough nozzle for 175s and far easier to keep the smoke in check without having to excessively pull fuel.
Tow truck
Play truck
Race truck
Pull truck
Each of these categories share some similarities, but if you go to far with the hardware, the tuning can't reverse it.
Yes, this is a very good option.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 44 Old 10-30-2013, 09:22 AM Thread Starter
Texas Proud
Don't have a whole lot of hills down in southeast texas, mostly flat hay fields lol. I had a thought about the 50s but never really hear much of them because everyone you hear talking about injectors generally doing 75s or in some cases even larger. Wish I would have did all this when I pulled the cab off now. I appreciate all the info, let's get some more going. Love hearing all the different options out there from people who have tried different things
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #8 of 44 Old 10-30-2013, 09:35 AM Thread Starter
Texas Proud
Message sent
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #9 of 44 Old 10-30-2013, 10:41 AM
andyjman's Avatar
Quoted: 2 Post(s)
What's the difference between the stock y pipe and a "modded" one? Does the modded one just have the little scoop for the egr cooler removed, or are there other differences? I have an egr delete kit that has yet to be installed, and it has a new up pipe to replace the section with the side port for the egr cooler. I have been thinking about doing one of the aftermarket ones if there's a huge difference between stock.
andyjman is offline
post #10 of 44 Old 10-30-2013, 10:52 AM
Gearhead2012's Avatar
Quoted: 2 Post(s)
I have 175/30's and love them. Still on stock turbo for now, waiting for Adrian (MTW) to finish building and testing a new turbo. On a full fuel tune with ficm tuning I could hit 17-1800* egt, but again on a stock turbo...more air would help drastically. You might get a little more power up top if you went with bigger nozzle injectors but I'd stick with a 30 or 50 if it were me (and it was me...lol) especially if you tow at all. Better atomization among many other factors. Lots of other things to consider too, regulated return and as other have mentioned, ported intake and turbo options all play a huge role. As soon as I get my trans in I'll take it to the dyno for numbers on 175/30 with stock turbo...then again with Adrian's turbo, then again after I change heads and intake to a fully ported setup...the last part is still months away, but I'll post dyno #'s for 175/30 on stock turbo in the next couple weeks if all goes well.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
