165cc, why not?? - Ford Powerstroke Diesel Forum
post #1 of 75 Old 10-29-2013, 12:37 PM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
165cc, why not??
How come the injector builders don't make a 165cc injector??
I would think a 165cc would be a "all around" cc for daily driving and towing 10k-15k with the right size turbo.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #2 of 75 Old 10-29-2013, 12:57 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Idk Rich. I know MPD makes/sells a 165/30 injector and seem to really like it. I personally hate the 175cc and 155cc injector options, but that is just my opinon as I think 155s are not enough of an increase over stock and 175s are too much of an increase over stock for the vast majority of folks looking at just mild turbo upgrades. I'm with ya man, 165cc seems like a great size.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 75 Old 10-29-2013, 01:14 PM
peixinho's Avatar
Quoted: 199 Post(s)
well I hate the 165 and 190 options
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #4 of 75 Old 10-29-2013, 01:17 PM
peixinho's Avatar
Quoted: 199 Post(s)
I think 165 is too much for people looking at a slight bump over stock (or as close to stock as possible) and I think 190 is too little gain over 175 but way more than most people want coming from stock
How about we settle on 170 and 182.5
KC Turbos
peixinho is offline
post #5 of 75 Old 10-29-2013, 01:29 PM
Chatham036's Avatar
Quoted: 136 Post(s)
If you have a tuner who is knowledgeable enough, they can write the larger injectors to function as if they were smaller as long as the nozzle size is not too large.
ie... you can have 175cc/stock injectors a tuner can make them fuel the motor the same as the stock 135 cc injector. There is no rule that the injector has to empty each time it fires
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is online now
post #6 of 75 Old 10-29-2013, 01:33 PM
peixinho's Avatar
Quoted: 199 Post(s)
I have alwasy wondered this... maybe everyone should start with a larger injector like 190/stock and then just tune it to 155 175 or 190... or you can just turn it up as you mod
KC Turbos
peixinho is offline
post #7 of 75 Old 10-29-2013, 01:41 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Although this is completely true, when you spend the amount of money on injectors a lot of people spend, why even upgrade if you're gonna fuel it like stock? Doesn't seem cost effective to drop that kind of coin on a 155/165/175/190 injector if you're not gonna have it empty every time unless it's a temporary thing as in waiting for "more air" via a larger turbo.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #8 of 75 Old 10-29-2013, 01:43 PM
peixinho's Avatar
Quoted: 199 Post(s)
Very good point
KC Turbos
peixinho is offline
post #9 of 75 Old 10-29-2013, 01:49 PM
BACKYARDIGAN
Quoted: 4 Post(s)
I TOTALLY forgot about this. This is VERY true. Damn you Rich, why did you suck me into this thread?? :
Anyways, Jay is ABSOLUTELY correct. (For the most part and assuming an infinite fuel barrel capacity) Only three things really affect how fuel is dumped into the cylinder when the injector 'fires' and that's ICP pressure, nozzle size, and PW.
While completely impractical IMO, there is nothing stopping anyone from running say a huge 275cc injector with small nozzles because (depending on the construction of the injector, i.e. plugged vs open spill ports) the injector will only dump as much fuel as the tuning allows for based on the three variables mentioned above. Hope this makes sense.
Nate
post #10 of 75 Old 10-29-2013, 02:22 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I'm of the slightly biased opinion of 175's. I personally like them a lot. 175/30's are proving to be a good combination for towing (with proper tuning and turbo sizing) and makes for a pretty badazz street setup as well. I would like to see some other options as well and have some thorough 'testing' done.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
