Injector/ turbo questions, recommendations. - Ford Powerstroke Diesel Forum
post #1 of 26 Old 10-28-2013, 11:05 PM Thread Starter
andyjman's Avatar
Quoted: 2 Post(s)
Hey guys,
I've been reading like mad on here, and I have a few questions about aftermarket turbos and injectors. I am new to the 6.0 aftermarket world, but by no means new to the 6.0 world. As I mentioned in my intro, I have worked on 6.0 engines for quite sometime but that was at the dealer, and working on stock motors.
Anyway, in the next 2 weeks or so, im doing the arp head studs, new head gaskets, egr delete, oil cooler, zerex red coolant swap, hpop oil fittings, blue spring upgrade, upgraded turbo oil drain, upgraded dummy plugs, stand pipes, etc. I'm waiting for the coolant filter, new coolant resorvoir, and a few other parts to show up before I dive in.
I am looking for some recommendations on what brands of after market turbos you have had good luck with, and what injectors you have paired them with. I'm still a bit confused about the numbers that are listed with injectors and what they mean. All of the high performance motors I have done before were gas motors with injectors rated in lbs, I'm kinda confused with ratings like 175/55 for example.
The truck so far has a 4 inch turbo back mbrp exhaust with no cat and no muffler, and all metal boost pipes under the hood.
I've been looking at warren diesel injectors, and either a power max turbo, of a mtw one.
Sorry if my questions sound stupid but I'm trying to get as much info as I can before I do all the work. I plan on using an sct tuner, getting the ficm tuned, and the tranny fully built pretty much at the same time along with the full brake upgrade setup, and most likely a 4 or 6 inch pro comp stage 2 lift kit.
Btw my truck is an 05 f350 crew cab, long bed 4x4 6.0 diesel.
Thanks guys,
Andy
andyjman is offline
post #2 of 26 Old 10-28-2013, 11:11 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Pm me for details on the above.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 26 Old 10-28-2013, 11:44 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Hey Andy, where n so cal are you? Who's gonna do the work?
I say get some warren 175/30 with a Barder stage 2 or if your not gonna tow go with some 175/75 with a Barder stage 3 turbo, that's a killer setup hands down
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #4 of 26 Old 10-29-2013, 01:32 AM
mechanix's Avatar
Good stuff right there.^^^^^
Eric
03 F350 Super Duty
ARP head studs
Warren 155/30% injectors
Barder Stage 2 turbo
SCT Tuner
EGR delete
35x12.50x20 Nitto Trail Grapplers
mechanix is offline
post #5 of 26 Old 10-29-2013, 02:20 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
You will never get 1.21 gigawatts without a ported intake manifold.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #6 of 26 Old 10-29-2013, 04:01 AM
bondajb's Avatar
Thats funny right there. ..
True. ...and funny!
My 175/30 with a Barder stg2 is an excellent combo.. I highly reccomend!!
with a ported intake also.. of course!! Lol
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #7 of 26 Old 10-29-2013, 11:41 AM
peixinho's Avatar
Quoted: 179 Post(s)
I always have to give the disclaimer about making sure you have everything else done before you look into big hp parts... It sound like you have a good start but I did not see anything about gauges, pyrometer, fuel pressure gauge,
To answer your question about sizes...
The first numbers like 155 175 190 205 etc... that is the amount of fuel that the injector body can hold. This would determine the maximum amount of fuel possible to be injectored
The second number like stock 30 50 75 100 etc... that is the nozzles size. It determines how fast the fuel gets dumped. The faster the fuel dumps the higher your temps and smokier the truck... but if you want to be able to dump all the fuel of those large injectors (especially at high rpms) you need larger nozzles. But if you make the nozzles larger it will also dump more fuel than wanted when doing things like towing heavy but if you want to make bigger power you need bigger nozzles.
Think of it like a syringe. 175 is how much fluid fits in the syringe and 30 would be the gauge of the needle.
Lately I have been thinking more and more that 155s is such a modest upgrade I would skip them unless you are wanting to stay close to stock.
175/stock = best bang for your buck in power
175/30 = good power and towing ability
175/75 = lots o power, smoke, and egts (hard to tow heavy)
190s+ will needs lots of other supporting mods
In my opinion the pmax and stage 1 turbos are a little too small for 175s
I would go with a stage 2 turbo if you tow heavy
I would go with a stage 3 turbo if you want mucho power!!!
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is online now
post #8 of 26 Old 10-29-2013, 12:08 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Originally Posted by peixinho View Post
I always have to give the disclaimer about making sure you have everything else done before you look into big hp parts... It sound like you have a good start but I did not see anything about gauges, pyrometer, fuel pressure gauge,....
Have you gotten an actual boost gauge yet so you can see what your turbo is actually doing vice pegging the MAP sensor?? Just sayin... :
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 26 Old 10-29-2013, 12:10 PM
peixinho's Avatar
Quoted: 179 Post(s)
Nope... my turbo just never goes above 33psi
KC Turbos
post #10 of 26 Old 10-29-2013, 12:15 PM
BACKYARDIGAN
Quoted: 4 Post(s)
then
Nate
