Intake system upgrades and maintenance - Ford Powerstroke Diesel Forum
post #1 of 35 Old 10-27-2013, 02:22 PM Thread Starter
With the other stuff out of the way I'm now wanting to look at intake system upgrades and maintenance. Here is the stuff I know of:
Aftermarket air cleaner
Aftermarket turbocharger
OEM metal cold side intercooler pipe upgrade
Aftermarket intercooler pipes
Aftermarket intercooler pipe boots
Aftermarket intake elbow
Methanol injection system
Nitrous system
Ported intake manifold
6.4 intake manifold swap
CCV re-route
Now, I know the factory air cleaner is generally regarded as being good up to 500 HP and it filters better than the aftermarket setups, but I plan on trying to push that number and am thinking of getting the S&B setup for the easier to change filter and the sound as well. From the reading I have done the factory intake elbow and intercooler pipes are not the restriction in the system and that the intake and heads are your first restrictions, so aftermarket units are not necessary unless those items are addressed first. I've also read the factory intercooler is generally good up to 45 PSI which is the point where the end tanks are compromised. I will be getting the aftermarket intercooler boots as they have shown to be better than the factory ones and my factory ones are beginning to tear. I won't be doing a ported intake or the 6.4 intake manifold swap. I've already done the CCV re-route and have it dumping above the front axle. I'm thinking of doing methanol injection though and passing on nitrous as this is my daily driver.
Anything I'm missing or more info on the above stuff?
The_Auto_Tech is offline
post #2 of 35 Old 10-28-2013, 02:10 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Sounds great.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 35 Old 10-29-2013, 08:06 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Just a FYI, the stock intake is the best $ can buy and good to 500HP.
So unless your also getting larger Inj's the majority of your mods will just lighten your wallet.
CT Performance, Inc. is offline
post #4 of 35 Old 10-29-2013, 08:35 AM
Java's Avatar
Matt from CED sucked the filter minder in on one of his trucks with 155/stock and a 62FMW. That's under 500.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #5 of 35 Old 10-29-2013, 08:38 AM
Quoted: 3 Post(s)
155 stock and that turbo and good tunes should make 500...
post #6 of 35 Old 10-29-2013, 08:41 AM
Java's Avatar
He told me it was under 500.
Java is offline
post #7 of 35 Old 10-29-2013, 09:43 AM
Pro fuzz's Avatar
Quoted: 29 Post(s)
My 155/stock and powermax billet set up sucks the filter minder ??? I think I need more air
2006 F350 KR cclb 155/stock full force powermax / WWII leveled carli 2.5 pintops 08&up full rear spring ouo 3link arms 36 toyo mt 4.30 yukon grizzly rear locker :yike
s:
New ride 2015 tow boss dpf & egr lost !!
Pro fuzz is offline
post #8 of 35 Old 10-29-2013, 10:37 AM
N.S.D.Q.
Quoted: 134 Post(s)
Replace the filter minder with a new one. Test and report your findings.
post #9 of 35 Old 10-29-2013, 10:51 AM
peixinho's Avatar
Quoted: 230 Post(s)
I made 583hp with just turbo and injectors using stock dirty air filter, stock intake manifold, stock intercooler, stock intake elbow, no water meth, no nitrous, etc...
Not saying they don't help... but I still find it odd that people limit the stock intake to 500hp???
Turbo and injectors are by far the best bang for your buck.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #10 of 35 Old 10-29-2013, 10:53 AM
peixinho's Avatar
Quoted: 230 Post(s)
Just FYI... very few people hit 500hp on 155s. Not saying it is not possible. But not common
KC Turbos
peixinho is offline
