H.p.o.d.s - Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 86 Old 10-27-2013, 11:58 AM Thread Starter
Superblazin's Avatar
H.p.o.d.s
Looking for more information and discussion on high pressure oil delivery systems, For injectors under 205 cc ( not a dual pump discussion)
I have read about Diesel sites set up and the testing that Bill over at PHP did on his truck. I believe his results netted 20-40 hp.
I would have to go back and read the thread but did he also put in a fresh hpop at the same time?
Has any one else done any testing of the hpods either diesel sites or home made with before and after numbers?
Do our trucks really benefit from it? Or with a fresh stock pump would we be also netting similar hp results ?
__________________
2005 Harley Edition CCSB, 30 over mahl pistons, delipped, bowled and coated, Carrillo rods, colt stage 2 cam, studs, a little head work, Custom intake, redneck compounds 66- s480, No limit intercooler piping, Elite diesel ZZ max intake manifold, 205cc /100% injectors, 150/150 Fass fuel pump, Regulated Return, Hellmans sump, CCV relocate, NADP Tranny, PhP ficm tune, Innovative Diesel custom tunes and some Redneck Lovin
Superblazin is offline
post #2 of 86 Old 10-27-2013, 12:07 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I'm sure it can be beneficial to performance. But is the juice worth the squeeze?
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 86 Old 10-27-2013, 12:58 PM
I'll be watching this as well. There's little info out there about it.
The_Auto_Tech is offline
post #4 of 86 Old 10-27-2013, 01:58 PM
Mitch has the hpods on his truck. Was easy to install, but who knows on hp gains. I believe his truck hold icp. He has 205/75's. I personally think it over priced... after looking at the parts to it- it can easily be made by urself and im sure you would save a bunch of money?
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 86 Old 10-27-2013, 02:52 PM
turbotibbo's Avatar
subscribing
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #6 of 86 Old 10-27-2013, 05:41 PM
pizza pig's Avatar
Its not as easy as you think...
pizza pig is offline
post #7 of 86 Old 10-27-2013, 06:20 PM
^nonetheless, can be made cheaper than $1156. It can be done.
bpd
Warren comp trans
04cr450 is offline
post #8 of 86 Old 10-27-2013, 06:30 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
^^^^^YUP.....
AND it really is NOT that hard if you understand the principles by which the system operates...Just sayin...
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 86 Old 10-27-2013, 07:22 PM
kdogg85's Avatar
I just think its funny that system has been out for a few years and just now it seems to be getting attention.
There's my derail for the night, is the purpose of that system to free up flow in the hpo system?
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #10 of 86 Old 10-27-2013, 08:56 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
In for the discussion...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
Closed Thread
