What is a Foil Delete? - Ford Powerstroke Diesel Forum
Old 07-22-2008, 05:26 PM
Chug-a-lug!!!
I've seen several sigs that said "foil delete". I couldnt find any info on this mod. What is it?
Old 07-22-2008, 05:34 PM
Chug-a-lug!!!
Also what about the high idle mod?
Old 07-22-2008, 05:36 PM
Almostdunfukinwidit
The foil delete is for the 99-03 trucks you can remove the foil from one of the intercooler tubes to hear more in cab turbo whistle
Old 07-22-2008, 05:46 PM
My first post . If you have the 4 aux switches , you can make aux 4 the high idle mod , I just did this tonight on my truck . You take the orange/blue wire from behind the fuse box (1 of 4 wires of the aux switches) Then you extend that wire down to the 11 wires (beside the ebrake) and hook it onto the purple/green(may be purple/blue i cant remember) . Then your done . Make sure the EBRAKE is set , and the trucks in PARK or Neutral , and hit the aux 4 switch up and the idle goes up to around 12-1300rpms (sometimes higher) for like pto(power take off) or to just warm the truck faster or cold winter days .
But im sure there is a how to on here somewhere. Good Luck
Old 07-22-2008, 05:56 PM
Chug-a-lug!!!
Awesome Ima gonna do it. Thanks!
Old 07-22-2008, 06:08 PM
what is the years that h/i mod will work? mine is an 07.
Old 07-22-2008, 06:14 PM
they actually have a flash that does this also, when you get in your truck and start it, don't touch the gas or brake after it starts, about 1miunte after idling it will kick your rpms up to about 1200, only works when the outside Temp is below 50 I think
Old 07-22-2008, 06:53 PM
Send a message via AIM to technoticmedia
i added heat wrap with foil-looking protection to my IC pipes
Old 07-22-2008, 07:01 PM
In the search function type high idle mod with the 6.0s its literally connecting a wire to ground or 12v and you get 1200-1400 its already wired in the consumer bundle, just have to find the right wire. 03 and later its a resistor mod to the gas pedal resistor, or more easily just get a chip with a high idle setting.
Old 07-23-2008, 07:45 AM
Not true, you can still connect to the PTO harness on the later models and get the high idle. My '08 has it.
