6 speed questions - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-25-2013, 02:52 PM Thread Starter
6 speed questions
I have been reading and reading and reading but I havent found much info on 6.0s with the 6 speed manuals trans. I just bought a 04 with 190k and plain to use it to tow (10k-30k pounds) mainly and a daily driver. Im trying to find good info on some towing tunes and other up grades such as turbo (as you lose boost so fast shifting, its hard to pull a load up hill) and maybe injectors down the road. The truck has just had the following done. new OEM injectors, new clutch, k&n cold air, hpop update, built proof egr cooler and oil cooler, ARP studs, and 3.5 straight pipe to 5 stacks, I just ordered coolant filter and oil by pass filter from sinister. I'm looking at getting a SCT live wire ts when I get the money because the truck doesn't have any gauges. Any help or info would be highly appreciated
fordfreak12 is offline
post #2 of 9 Old 10-29-2013, 06:23 AM
My buddy has a 6speed on his and he said just got the sct x3 and with the basic canned tunes the turbo stays lit while shifting from gear to gear
2008 F350 Lariat. Done: stud, RCD pushrods lifters valve spring porrted intake manifold, ported fuel rails, fass 150, sb intake, sinister egr delete, 5' exhaust, mini maxx with Gearhead tunes, RCD triple disc tc input shaft intermediate shaft reverse hub, red eagle clutches, transgo shift kit
Reezy71x is offline
post #3 of 9 Old 10-29-2013, 02:49 PM Thread Starter
Thanks for the reply. My plan is to email a few of the tuners and see what they can do. I see you have some innovative tunes how do you like them, I've read a lot of good things about them.
post #4 of 9 Old 10-29-2013, 03:20 PM
Ford7three's Avatar
Give PHP and Innovative a shot for tuning! We deal with both and have very happy customers running both tunes.
Ford7three is offline
post #5 of 9 Old 10-29-2013, 03:26 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
I have the same issues, then again...I have a 7.3
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #6 of 9 Old 10-29-2013, 03:54 PM Thread Starter
One of my buddys has a 01 7.3 his isn't as bad as mine but i thought they have different style turbos, he put a wicked wheel ll in his and loves it. We traded trucks for a day to see the difference in them and we both said his was easier to drive but his had less power( with out his tuner). My truck weighs 9400 ish pounds as well. So that probably doesn't help.
post #7 of 9 Old 10-29-2013, 03:58 PM
Winning DUHHH
Quoted: 8 Post(s)
i have a WW also, but im telling ya...it drops to maybe 1-2 lbs when letting off to shift
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
post #8 of 9 Old 10-29-2013, 04:29 PM Thread Starter
Can any one tell me what tuning the ficm does exactly and if its safe to do and if you can run custom tunes with it?
post #9 of 9 Old 10-29-2013, 06:03 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Basically, allows for better throttle response off the line, and some have seen better MPG. Yes you can run with a SCT custom tune or any other type of PCM programmer.
Safe..... Depend on the driver and health of motor. Head gaskets have been known to go with stock tuning. EGT wise, the higher the FICM tune rating, the higher the EGT.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
