Fuel injectors - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-24-2013, 05:06 AM Thread Starter
Fuel injectors
Was talking to a local shop that supposedly works on a lot of 6.0's.
Mostly oem work, not much in the way of performance work.
We were talking about replacing fuel injectors and he said that all 8 injectors on a 2005 powerstroke are NOT the same. He said that there was one injector that was the command injector or something like that. He said it was different than the rest of the injectors. Now, i am not a mechanic by any stretch of the imagination, but that is something that I have never heard of when talking about these engines.
Any thoughts ?
4realestate is offline
post #2 of 6 Old 10-24-2013, 06:02 AM
HP MACHINE's Avatar
Quoted: 104 Post(s)
I use a PHP ficm tuner and remember something being said that when programming the
ficm , to remove the main injector relay to prevent damage to the #1 injector .I don't
know that the injectors are any different , but maybe he's rite about the command
logic .
There are gentlemen on here with tons of knowledge that will know for sure .
HP MACHINE is offline
post #3 of 6 Old 10-24-2013, 07:40 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
There is zero difference among the injectors.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 6 Old 10-24-2013, 07:58 AM
peixinho's Avatar
Quoted: 173 Post(s)
ummmm... sounds like you might want to take your truck to a shop...
All 8 injectors are the same and are all interchangeable
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #5 of 6 Old 10-24-2013, 08:25 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yup. The injectors are controlled by the FICM. Your mechanic is talking out his butt. You might want to consider finding a new one.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #6 of 6 Old 10-24-2013, 04:49 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
He is referring to a 7.3 concerning the AB-AD-AA injector difference I believe
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
