How to verify Powermax? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 10-23-2013, 05:02 PM Thread Starter
f250ghost's Avatar
So the truck I bought supposedly has a Powermax turbo in it....according to the previous owner. It seems louder than a stock turbo, but it doesn't scream like I've heard most Powermax turbos scream. So my question is this...how would I go about verifying it's not a stock turbo? Are there any external differences that I could see when I pop the hood? Or would it be one of those things where I need to remove the turbo?
-Ben
2011 F250 FX4
6.7 PowerStroke
f250ghost is offline
post #2 of 14 Old 10-23-2013, 05:35 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Got a picture of the turbo in the truck??
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 14 Old 10-23-2013, 05:51 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1811 Post(s)
Feedback Score: 4 reviews
The most common way is the word "garrett" on the outlet is upside-down as the turbo sits in the truck
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is online now
post #4 of 14 Old 10-23-2013, 06:09 PM Thread Starter
f250ghost's Avatar
No sir but I will take one tomorrow.
Thanks...I'll have to look for that. The only reason I doubt its true is because the guy was one of those people who basically gave a shop a blank check to make his truck so he wont have any other issues with it. I have a feeling he got taken a few times...for example...it's got the bulletproof kit in it from BPD...except they didn't stud it when they did the gaskets and everything else.
-Ben
2011 F250 FX4
6.7 PowerStroke
post #5 of 14 Old 10-24-2013, 09:34 AM Thread Starter
f250ghost's Avatar
Welp I just checked and the Powermax is right side up...theres also a "remanufacture" sticker on the turbo...so I guess its just a stock replacement huh?
-Ben
2011 F250 FX4
6.7 PowerStroke
post #6 of 14 Old 10-24-2013, 10:28 AM
Yep, the "garrett" is right side up....looks like a stocker to me. It might have an upgraded wheel (maybe) but the outside of the housing looks stock. Might wanna replace that boot though, its probably leaking 1-3lbs of boost with how much oils coming out of it..
post #7 of 14 Old 10-24-2013, 11:21 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 8 Post(s)
Pull your intake off and see how big the compressor wheel is, it's a lot bigger than stock. Take a pic
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #8 of 14 Old 10-24-2013, 11:58 AM
smoke=cool=little kid
Its stock, power max has a square wiring harness block, yours is round. Idk how to upload pics or else I'd send you a side by side comparison of a power ax an stock turbo. Also the way the bolt pattern is for in compressor side tells me its a stocker even more, unless its an old pmax. Although! It could be an 03' reman turbo which wouldn't be bad at all
2004 F250 CCSB 44
Typical mods and performance parts
SCjake is offline
post #9 of 14 Old 10-24-2013, 12:44 PM
BACKYARDIGAN
Quoted: 4 Post(s)
It's not a Powermax, that's for sure. Looks pretty stock of some sort to me.
Nate
post #10 of 14 Old 10-24-2013, 01:26 PM Thread Starter
f250ghost's Avatar
Its definitely not an 03...I had an early 03 about 3 years ago and that thing screamed lol...this is is kinda loud but nothing like a powermax or 03 turbo.
I contacted the previous owner because he told me it had a powermax in it...turns out it doesnt! He said the shop that installed it ordered it and he's having them fax the paperwork over so he can look at it. I called the shop the work was done at and they were "too busy" to talk on the phone and wanted me to drive an hour and a half to come to their shop.
He also said the truck was just fully serviced...after seeing the way my oil and fuel filters looked...there's no way that could be true either. Finally...when I bought it he said it had the BPD kit in it...the cooler and valve are still there so I assume it's the BPD EGR cooler...so maybe one thing he said was done actually happened. I don't think it's so much this guy flat out lied to me as much as it's the shop he took it too taking advantage of him because he didn't know anything about diesels.
-Ben
2011 F250 FX4
6.7 PowerStroke
