Blown y pipe - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-23-2013, 04:46 PM Thread Starter
turbotibbo's Avatar
Blown y pipe
Will a blown y pipe cause high egts . Mine is badly blown and when I step on it the egts are climbing much faster and to levels I have not seen even on my high tho tune . I have the sinister y pipe to install along with a power max .any info from other members who experienced a blown y pipe would be helpfull , thanks
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #2 of 7 Old 10-23-2013, 05:24 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Yes, a blown y-pipe will cause that. It's a boost leak so you're getting all the fuel into the engine but not all the air.
dhanna6powerstroke is offline
post #3 of 7 Old 10-23-2013, 06:27 PM
bondajb's Avatar
Check the bellows on the sinister pipes.. if they have exposed braiding internally.. there have been a few failures documented..
lets get your old ones fixed..
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #4 of 7 Old 10-23-2013, 09:47 PM Thread Starter
turbotibbo's Avatar
the sinister unit has no bellows , that's one of the reasons I picked this one , its also looks less restrictive , ill post some pics soon. heres the link Sinister Diesel 6.0L Powerstroke Y-Pipes
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #5 of 7 Old 10-24-2013, 06:43 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1668 Post(s)
Feedback Score: 4 reviews
are the slip joints leaking? Have you crawled under and checked for soot marks with a light?
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is online now
post #6 of 7 Old 10-25-2013, 04:53 PM Thread Starter
turbotibbo's Avatar
No wonder I had high egts the y pipe was in two pieces . Split in two at the bellowBlown y pipe-image.jpg
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #7 of 7 Old 10-25-2013, 05:53 PM
Mod Newbie
Quoted: 19 Post(s)
Originally Posted by turbotibbo View Post
No wonder I had high egts the y pipe was in two pieces . Split in two at the bellowAttachment 186969
That'll cause it
