MAX tune for 6.0 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-23-2013, 03:38 PM Thread Starter
MoserJR82's Avatar
MAX tune for 6.0
I have a studded 6.0 with 155,000mi. See all my mods/changes (really not much) in my sig.
That said, I'm looking to get a couple of custom tunes. Right now I'm running the Spartan hybrid race. I have a buddy with a banks tuner on a 6.0 and runs it at 7 (highest setting) and it's a little quicker than mine. I want a maxed out custom tune that's not going to destroy anything, including my mileage. I don't drive with a lead foot, but want the power when I go to the floor.
Suggestions please! I know everyone says to try and see what you like, but without looking I don't even know where to start. Like inovative? Why Like Matt and SRL? why? My current tune shifts HARD (I think the TC is almost always at full lock) I don't mind it but wouldn't mind it smoothed out a bit.
Thanks in advance guys!
2005 F-350 KR, CC, SB 6.0L
Sinister EGR Delete
Final Charge Coolant
Rotella T6 5w40
Sinister Coolant Filter
MBRP 4" turbo back straight pipe
Blue Spring Upgrade
Droid Torque App
SCT X3 Spartan Hyrbid Race Tune
ARP Head Studs
Aftermarket degass cap
Cowl hood (not functional)
Atlas 80 PHP FICM tune
Rebuilt FICM thanks to FICMRepair.com!
Rancho RS9000X front shocks
MoserJR82 is offline
post #2 of 12 Old 10-23-2013, 07:13 PM
seanol's Avatar
I have used two so far in my truck. Both are SCT based, one is Looney Wild from Quick Tricks and the other is the SPD tune from Truck Source Diesel. Both tunes are very high power tunes and mileage will suffer if you are on it all the time.
That said, on cruising I got about 1 mpg more using these tunes than stock and 1 mph over Looney using the SPD tune form Truck Source Diesel.
Both have great manors but both drive differently. The Looney has the light switch effect. You have a normal truck up to about 60% throttle and then the truck takes off.
The SPD tune pulls hard all the way up with no light switch effect at all. Both are a little smokier than stock but nothing like I expected. If I floor it I will get a small cloud but nothing that clears intersections. Once running both tunes only give me a small puff.
Others can let you know about their results with their tunes. I have found that each truck seems to respond differently so it pays to try some different tuners. The tunes are not very expensive when you consider what you get.
Good luck,
Sean
seanol is offline
post #3 of 12 Old 10-24-2013, 01:11 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
We can get you setup with a couple different tunes if you are interested. We offer anything from mild tow tunes to all-out extreme tunes. Feel free to contact me if you are interested and I will help you out.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 12 Old 10-24-2013, 02:16 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I've ran a couple and prefer DP.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #5 of 12 Old 10-25-2013, 08:40 AM
Gearhead gets my vote hands down.
SOOTIE is offline
post #6 of 12 Old 10-25-2013, 03:57 PM
turbotibbo's Avatar
gearheads srl ++
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #7 of 12 Old 10-25-2013, 04:13 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Originally Posted by turbotibbo View Post
Hear heads srl ++
Gearhead...
Ive run lots of tune from different manufactures and to be honest every truck reacts differently to every tune writers tunes. I ran Matt's SRLxx (extremes full fuel tune) and Tonys Extreme tunes for quite a while but since Chris at TSD started doing email tunes again I went with his and his SPD is hands down the quickest tune I've had ever! Spool up was amazing the very first time... Others gave me several tune revisions only to have a slow spool but Chris nailed it the first time.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #8 of 12 Old 10-26-2013, 12:03 AM
huhner5's Avatar
Chris @ TSD...only tunes that I will run.. pure awesome
15 F150 Platinum 3.5 Ecoboost, 1.5" Leveling Kit, "PLATINUM" Bedside Emblem, Tint, LED Fogs
Sold: 06 F250 Lariat To much to list
huhner5 is offline
post #9 of 12 Old 10-29-2013, 05:18 AM
Are you by any chance you're the other 6.0 runnin around Waukee?
2008 F350 Lariat. Done: stud, RCD pushrods lifters valve spring porrted intake manifold, ported fuel rails, fass 150, sb intake, sinister egr delete, 5' exhaust, mini maxx with Gearhead tunes, RCD triple disc tc input shaft intermediate shaft reverse hub, red eagle clutches, transgo shift kit
Reezy71x is offline
post #10 of 12 Old 10-30-2013, 05:50 AM
huhner5's Avatar
Nope.. not me.. saw Minnesota here
huhner5 is offline
