Devils own Water/Meth injection - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-23-2013, 12:29 PM Thread Starter
Quoted: 8 Post(s)
I see a lot of people posting about the Snow performance Water/Meth injection. Obviously its well regarded. Has anyone used the Devils own system or have thoughts/opinions about it???
I was looking at the stage 2.
http://www.alcohol-injection.com/en/173-diesel
Ron
Ron-M is offline
post #2 of 9 Old 10-23-2013, 02:16 PM
Chatham036's Avatar
Quoted: 136 Post(s)
I just purchased and installed a kit from Alcohol Injection Systems and REALLY like the quality of the parts especially the tank that they have. The AIS pumps also carry a lifetime warranty.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #3 of 9 Old 10-23-2013, 03:58 PM
colonel angus's Avatar
Quoted: 2 Post(s)
I spoke with DO at length, i mean 2 hours about diesel ford injection nozzles on and on and on. they answered every question and even suggested i make all the mods i was going to and ensure the truck is 100% then call them back and order.
ZERO pressure. It all comes down to the controller and how much you want to F with it.
If you want to turn knobs and modify it constantly then snow with a dash kit, if not then they all do the same thing, with the same components.
I'm betting once it's setup correctly then you won't mess with it after that, just flip an upfitter switch and energize it.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #4 of 9 Old 10-23-2013, 04:06 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Chatham360, what kinda $ do you pay if you don't mind sharing????
Colonel Angus- so Im looking for one that pretty much takes care of itself. What kinda mods did they suggest you do first?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 9 Old 10-23-2013, 05:10 PM
Quoted: 2 Post(s)
Get my intake, madmax turbo, and tunes figured out too see if i still need it for heat reduction or want it for more HP to go over 600 hp. Kit should be good for 40 - 60 hp and i should be at 550 or more before adding meth..
d
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #6 of 9 Old 10-23-2013, 05:16 PM
Chatham036's Avatar
Quoted: 136 Post(s)
$329.99 for the Stage 1 kit that I chose to use
You can like our page on Facebook (power hungry performance) and view the album for the system
post #7 of 9 Old 10-23-2013, 05:41 PM Thread Starter
Quoted: 8 Post(s)
I looked at the system and it looks like its on or off depending where you set it to come on. I didn't see where you could set the full on at any certain boost. I'll have to read up on it.
Ron
Ron-M is offline
post #8 of 9 Old 10-23-2013, 05:48 PM
Chatham036's Avatar
Quoted: 136 Post(s)
Yes, it comes on at 100% at 18 psi
There is not a progressive rate controller on this system though AIS does have an optional progressive rate controller just for that reason.
post #9 of 9 Old 10-23-2013, 06:01 PM Thread Starter
Quoted: 8 Post(s)
D
Really sounds like what I'm looking for with good customer service to boot.
I have almost everything here now to tear into my truck. Arps, new pushrods, all the updated stuff. oem oil cooler although I only have 3* to 8* deltas (have it apart so why not). Over $2000.00 already and still buying. I can't make my mind up on the MTW wicked wheel equivalent for the stock turbo or the stage 1. Also trying to decide if I should go with 155 or stock sticks. I don't care about burning up the road but want a long lasting strong truck.
I live in Maine and pull a 15,000lb fifth wheel camper to upstate NY. One hill on the Mass Pike is about 3 miles long and quite steep. One of my reasons for wanting the water/meth injection.
Ron
Ron-M is offline
