Help: Fuel Pressure Gauge - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-21-2013, 10:30 AM Thread Starter
ConJohnRobTx's Avatar
Hey guys,
I am looking to get some gauges and before I do that I want to use a manual gauge to check my fuel pressure before I do the electrical one. I want to use the fuel test port.
THIS IS WHAT I NEED TO KNOW : what adapters and hose do I need to check it manually and also I could use it to relocate my sender when I get the electrical gauge. I would like to buy everything locally and not order stuff from online.
If anyone could help that would be great. AND yes I have seen other post on this issue sort of but I need further advice
2004 F250 6.0 Lariat CCSB FX4
5" DE Turbo Back
Edge Insight CTS w/ EGT Probe
ConJohnRobTx is offline
post #2 of 7 Old 10-21-2013, 11:07 AM
snafu!'s Avatar
The adapter you will need is a 12mm x 1.5 oring to 1/8" npt, then a 1/8" hose to relocate the sender.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #3 of 7 Old 10-21-2013, 11:31 AM
portcity_gt's Avatar
Quoted: 1456 Post(s)
What he said.
the adapter can be found on ebay for 10 bucks.
as far as the mechanical gauge, you can buy a oil pressure test kit from harbor freight for $20, it comes with a pretty nice gauge with 6' of hose and various fittings. It comes with a 12mmx1.5 fitting but its not o ring, but it will "work" good enough just to test your fuel pressure.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 7 Old 10-21-2013, 04:59 PM Thread Starter
Thanks guys I appreciate it!
5" DE Turbo Back
post #5 of 7 Old 10-21-2013, 05:18 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
To piggyback here... The adapter is the strictly diesel one right? Just a DIY version?
Do you need a certain hose for the fuel? Do you need that bleeder piece at the end?
MrOneEyedBoh is offline
post #6 of 7 Old 10-24-2013, 07:25 PM Thread Starter
Would this work for what I need? I know its been a few days sorry.Autometer 3227 4AN Braided Pressure Gauge Hose Kit | eBay
5" DE Turbo Back
post #7 of 7 Old 10-25-2013, 05:13 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
No, it's not gonna work.
You need metric adapter for the fuel psi test port on the upper fuel filter housing.
The fuel psi test port is M12x1.5 o-ring male fitting. Most aftermarket fuel psi sensors are 1/8npt male fittings. So you need to get a adapter that is M12x1.5 o-ring male to a 1/8npt female.
You have choices, you can directly hard line the M12 fitting to the test port and mount the sensor directly to the M12. Or you can buy or have a local hydraulic shop make you a hose to locate the sensor away from the motor.
Here is the adapter in the first link. The second link show the relocating hose style.
http://www.amazon.com/gp/aw/d/B007SYDD64
http://www.dieselmanor.com/diy/DM-FPA60_installed.htm
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
